Welcome to CamaroZ28.Com, the ultimate Source for Camaro enthusiasts! Here you can join over 90,000 Camaro enthusiasts from around the world discussing all things related to Camaros and more. You are currently viewing as a guest which gives you limited access to view discussions
To gain full access to our forums you must register for a free account. As a registered member you will be able to:
Participate in over 40 different forums and search/browse from over 5 million posts.
The car:
1997 Camaro Z28 M6, 112k mi
Short Stick, K&N FIPK, and possibly a Hooker Catback soon
Trying to decide between 3.73 and 4.10 rear end ratios.
I'm looking for something universal, good for auto-x, daily driving (fuel economy), drag racing, and highway driving (# of RPMS @ 70mph = exhaust volume)
Also, I want them for a 8.5" Series 2 carrier? or Series 3?
What else do I need to know? I'd be having them installed, and already have a quote from someone who's done a rear end swap before. I want to have the rear end fluid replaced, so I'd need to buy some more, and I'll want my spedo recalibrated via PCM quickly therafter (either do it a week before a tuner is in town or have a PCM4Less/MadZ28 PCM ready to go.
This ad is not displayed to registered members. Register your free account today and become a member on CamaroZ28.com!
I'm going to have to vote 4.10, seeing as ~99% of all M6 drivers go with 4.10's if they upgrade gears, same as ~99% of all A4 drivers go with 3.73's. There are a few exceptions to the rule (I ran 4.10's w/A4 ) but law of average says 4.10's are going to be best suited for your M6 .
Mileage? Well, on the highway, it may drop slightly ... ~1 or 2 mpg maybe? But your cruise RPM's are only going to go up about ~300 - 400 RPM in 6th gear @ 70. Not bad.
For drag racing, with the mods you're listing, the 4.10's will leave you with plenty of gear left at the end of the 1/4, crossing the line in 4th gear.
For street driving and even auto-x'ing, you'll always have a "right" gear to grab (they'll be shorter, but more responsive).
You are looking for 3-series gears for a 7.625" (7-5/8") 10-bolt though ... not 8.5" (unless you've done a conversion??? ..... doubtful) .
__________________ 2002 Z28: M6, 3.73's, Strano Suspension (HP3) - Goes, Turns, Stops, and even Flies. 1993 Z28: Road Race car - LT1/T56 - SoloSprint #95 - Goes, Blows, Goes and Blows. 1973 Camaro: Dad's - 355, TH350, 4.10's. 1981 Z28: 383 c.i., TH350, 3.42's - sold August, 2000.
Reason: Bad math!!
Currently got 3.23's because I had 4.10's in the 3.23 housing, behind the A4, then busted 2 teeth off the pinion, so the 3.23's went back in, then ~2 weeks later and the A4 committed suicide , so then in went the T56!! I've got a set of 3.90's at home waiting to go in . I'll give a report on them in the spring!!!
With your mods, I'd say keep the 3.42s IMHO. You probably trap less than 105mph in the 1/4mi. Get a set of 27" tall drag radials for the strip and go through the traps in 3rd gear (which should be around 5800rpm for a 105mph trap speed). That way, you have the same streetability and no loss of gas mileage. The 3.42 is a pretty good overall ratio, and I think 4.10s are just way too much gear for a bolt-on car. Oh yeah, the ring gear size on the 3rd-4th Gen 10 bolt is 7.625".
__________________ '70 Yellow Ford Mustang Mach I 351C 4V/4-Speed 50k miles (STOCK) '99 Electron Blue Metallic Honda Civic SI (STOCK) '95 MPRM Pontiac Firebird TA M6 (NOT STOCK) http://www.cardomain.com/ride/807913
I've found the cam to be the driving issue for gears. My HotCam really like the 3.73. I found the 4.10 to be too low for anything other than drag strip blasts. The 3.73 makes good use of 6th and with the HotCam it enjoyed the lower ratio off the line.
After I went to a P1SC and milder cam, I went back to the 3.42 because the 3.73 was too low, as I was leaving stoplights in 2nd about 90% of the time. The cam defines the gears. Unless of course you only want braggin rights at the drags, then you might want a 4.10 cuz it'll shave another tenth or two for ya.
