Stall Converter
Old 01-18-2015, 06:22 PM
marine1bird's Avatar
Stall Converter
Will I have to get another tune when I install a stall converter?
marine1bird is offline
Old 01-20-2015, 08:36 PM
FirstYrLS1Z's Avatar
Re: Stall Converter
more info !
another tune ? so you've already had a tune ?
what stall is your plan ?
FirstYrLS1Z is offline
Old 01-21-2015, 06:31 PM
Re: Stall Converter
Yes the car has a tune because it has a custom grind cam.I was thinking of getting a stall from after my warranty runs out on my rebuilt 4l60e in a couple of months.The builder would not give a warranty with a stall converter installed.I was thinking about maybe somewhere around 2600 to 3200 range for a stall.
Old 01-23-2015, 06:27 AM
Re: Stall Converter
looking at your sig,looks like you're set up for street fun and dragstrip. What's missing is a stall. Considering a factory/OEM stall is about 1800,a 2600 would be a complete waste of money,time,effort,even a 3200 would still leave you wanting more. 3500/3600 range,from CircleD or Yank,would be a good match for your 3.73s'.
Old 01-23-2015, 06:31 AM
Re: Stall Converter
Instead of starting at 1800 where high torque application causes a sort of engagement to the drivetrain and having to climb/accelerate thru all that low horsepower part of the curve, a 'higher' stall will start more into the 'meatier' part of the curve. You're not wasting time(1/4 mile ET) climbing thru it. And that applies to every gear.
Old 01-23-2015, 06:01 PM
Thumbs up Re: Stall Converter
Thanks for the info.So I guess I will look into a 3600 converter.
Old 01-23-2015, 08:05 PM
Re: Stall Converter
Don't know where you're located,but one of the best ways to find out what you like is get some rides(as a passenger) in some stalled f-bods. Knowing what convertor(brand/rated stall rpm and gears) is in it,pay attention to low throttle response rpm to get vehicle moving and medium throttle gear kickdowns.
Old 01-24-2015, 07:03 AM
Re: Stall Converter
I live in Savannah Ga. Most people around here have the LS1 and the ones that have the LT1 will not give much info on their setup.Have you had any experience with Protorque converters?
Old 01-24-2015, 07:35 AM
Re: Stall Converter
never heard of them.
doesn't matter if the rides are in LS1s',you'll get the info/experience you'll need to make a decision.
Old 01-24-2015, 08:04 AM
Re: Stall Converter
Typically,'on the shelf stocked' convertors such as B&M-Hughes-TCI have a lot of slippage(looseness)and don't give the expected performance. Custom convertors such as Yank and CircleD will be tighter at low end and give the expected performance on the street and strip.
You get what you pay for. convertors in the $300-400 range don't measure up to convertors in the $700-800 range.
The ONLY advantage of the 300-400 convertors is their slippage will allow a cammed motor to idle high enough without trying to push thru the brakes at stop.
Old 01-25-2015, 12:02 AM
Re: Stall Converter
Are there any dealers on this site for Yank? Where is the best place to get one?
MichiganSkip
06-08-2015 10:30 AM
thenewkid
04-12-2015 07:42 PM
Javier97Z28
09-08-2002 07:23 AM
veryslowfbody
08-22-2002 04:31 PM
TrouserSnake
07-22-2002 05:34 PM
Quick Reply: Stall Converter
