ANY way to determine gear ratio ? by looking at gears ?
Old 05-05-2005, 06:00 PM
Sergio's Avatar
I have a set of used rear end gears.
I see no numbers that look like 3.23, 3.73, etc...
The big gear has 41 teeth, the Pinion gear has 12 theeth.
There are some numbers on the big gear:
12.41 26013008XXX
The pinion gear has the following on the 'head'
21013009-12-41-GM
Note some numbers could be false as they are very hard to read.
Our (4th gen Fbody) rear end's are 7.5" 10 bolts right ?
Sergio is offline
Old 05-05-2005, 06:26 PM
damnyankee36's Avatar
Re: ANY way to determine gear ratio ? by looking at gears ?
The numbers 12.41 26013008XXX and 21013009-12-41-GM tell it all. The 12 is the number of pinion teeth and the 41 is the number of ring teeth, (which you already know). Just divide the 12 into the 41 which gets you 3.42:1 ratio.
damnyankee36 is offline
Old 05-05-2005, 06:29 PM
Sergio's Avatar
Thanks ! Learning everyday
Sergio is offline
PCLZ28
12-24-2015 05:19 PM
anmar A
05-02-2015 06:59 PM
thenewkid
04-12-2015 07:42 PM
mattstrike
03-10-2015 04:46 PM
07-04-2005 05:00 PM
Quick Reply: ANY way to determine gear ratio ? by looking at gears ?
