Preload on gears..
Preload on gears..
What are you guys setting the preload to for your pinion and carrier bearings? I got the solid pinion spacer that came with some shims, im assuming those shims are used to set the preload for the pinion?
TIA
Craig
TIA
Craig
Well I looked at my service manual and it says to insert a .004" shim on each side to set the carrier preload. I went threw my shims and there isnt any shims smaller then .010". I have the Ratech Complete Gear Install Kit.. am I missing something here?? Should I just mic what I take out and put that same amount back in??
08-24-2015 06:41 AM
CoUnTryMuZiCZ28
03-08-2004 11:08 PM
