play in the rear (please help me)
Old 10-16-2004, 05:08 PM
firstz's Avatar
ok hears the thing i got a used rear put in b/c i broke the last one by hiting a curb duing donuts. every time i spine my tires it hops now and if you look at the tire marks you can see one of the tire marks move sise to side and my friend said my wheel was jumping up and down really bad when spined my tires so i jaked up my car the right wheel has play im not sure that is spose to be ther i took it back to the place that put it in they said its spouse to do that. i dont know about that my car never hoped before all the bushings looked good to. any help will be great
firstz is offline
Old 10-17-2004, 08:28 PM
Kris93/95Z28's Avatar
Re: play in the rear (please help me)
Try making sure all bolts are THERE and TIGHT...
Bent Wheel?
Did you reuse the wheels you were driving on when you hit the curb?
If that doesn't do it, I'd look into replacing the Panhard bar bushings.
I know when mine on my 93 were shot the rear would rock side to side when going around corners, etc...
Kris93/95Z28 is offline
Old 10-18-2004, 12:27 PM
firstz's Avatar
the panhard bushings is fine and i replaced the wheel with the crack and the other wheel is fine just a scrap in the inside. my friend said it might be the tire he said it might of broken the belt inside witch my cause my problem. im just going to move the front tires to the back and see what happens i dont think it will make a difference but im at the point to try any thing. any more input will be be great though thank you for trying to help me.
firstz is offline
Old 10-27-2004, 04:42 AM
MentalCaseOne's Avatar
This may be a stupid answer but have you checked your shocks?? Wheel hop sounds like it to me.
Marvin
MentalCaseOne is offline
Victor Lamb
08-26-2017 02:52 PM
HarleyZ28
10-05-2015 06:23 AM
PROJECT X
04-17-2015 12:13 AM
Absolute Z28
07-19-2002 02:21 PM
Quick Reply: play in the rear (please help me)
