Noise from Clutch/Transmission
Old 04-21-2015, 10:26 AM
blkWidow's Avatar
Exclamation Noise from Clutch/Transmission
So I will try to explain this as best as possible. Mostly from a stop when I engage the clutch (mostly for a slow and smooth start, not a hard go) there is a slight grinding/rubbing sound coming from the trans/clutch area. It last for the period of engaging the clutch and maybe a second afterward.
Sometime this will happen is second gear also in situations where I was slowing down to stop but then started to go again and I engage the clutch while in second and accelerate.
No problems in any other gears but I don't start in any other gear. I will note that the quicker the launch the noise duration is shorter or non-existent.
Is this the clutch or am I losing my first and second gear?
I will also note that I don't feel any slipping from the clutch or any type of burning smells.
I have a 97 1LE Z28 with 6MT (if the talk about the clutch wasn't clear what trans I have).
blkWidow is offline
Old 04-21-2015, 10:27 AM
blkWidow's Avatar
Re: Noise from Clutch/Transmission
Also, I just took it to a shop and they said that everything was good? But I still am not real sure that is the case.
blkWidow is offline
Old 04-21-2015, 01:56 PM
blkWidow's Avatar
Hey the search function works...sorry guys but this has been asked:
https://www.camaroz28.com/forums/dri...ration-812436/
blkWidow is offline
autoxr166
09-25-2015 04:21 PM
rideordie
09-07-2015 08:22 AM
colts0455
13
08-07-2015 09:15 PM
GT what?
07-14-2015 10:17 PM
colts0455
07-07-2015 07:19 PM
Quick Reply: Noise from Clutch/Transmission
