Lt1 clutch recommendations
Re: Lt1 clutch recommendations
I third that.... I have a spec stage 3 and I love it. Not heavy at all and I've never had a problem with it. Can't say there aren't others that are good too, because I've never had another brand in my camaro.
simple ebay stock plate with performance disc I have run this set up for years no problems and cheap
under 300 you can get a nice setup
I would try a dual friction a f1 racing clutch from gripforce on ebay. I have used the ram version of this clutch and it was slipping at 8000 miles on a bolt on motor. I now have the six puck f1 racing clutch on a h/c motor and its great,but you need a 3.73 or higher ratio or you will get clutch chatter.The quality if these clutches are top notch...
http://www.ebay.com/itm/F1-MULTI-FRI...10f3fa&vxp=mtr
