LS7/ LS2 clutch in an LS1?
Re: LS7/ LS2 clutch in an LS1?
Having just surpassed 100k miles on my stock LS1 clutch, I've been wondering the same thing. I'm also interested in the LS9 clutch (as I have plans for power in excess of a stock LS7 someday). Does anyone know if these are compatible?
EDIT: I just found that Katech makes kits to upgrade to the LS9 clutch. They're not cheap -- the LS9X kit is a couple hundred dollars more expensive than the McLeod Street Twin, which is one of the most expensive and highly regarded aftermarket clutches out there. The LS9R kit (another 100+hp of rated holding power) is a couple hundred dollars more than that.
The 2001 and 2002 Z28s and SSes came with the same clutch used in the LS6-powered C5 Z06 (405hp). I wouldn't automatically assume that the LS2 clutch (rated for the 400hp LS2) would be any significant improvement.
At this point I'm not convinced that my clutch is bad. I still have a strong feeling that the slave or master are at fault. 31k miles and 11 years of clutch dust has solidified and is making the pedal stick imo. I'm going to replace those with new units the same time I install the clutch and flywheel.
