LS1 VS. LT1 rear....
Re: LS1 VS. LT1 rear....
the only thing that's different is the ABS set-up. LS1 cars have 4-channel ABS with sensors on each axle tube and LT1 cars have 3-channel ABS with one sensor on the pumpkin.
this of course only applies if you're trying to swap them.
I was about to ask about that torsen differential. Did any 99 SS's come with that? What all can you do to your rear end that will make it as strong as it can be? Thanks, Brian Kaiser
All 93-98 had Auburn diffs, and all 99-02's had Torsen diffs, with the exception of a few 98's. 10 bolts do suck bad, the only way to get a little more life out of them is NO sticky tires, not even Drag Radials. A solid pinion spacer and TA girdle with stud kit may help some, but thats about it.
Stick with the Torsen if you must chose between the 2.
Auburns burn up really quickly if you put on DR's,the TORSEN held up much better and were trouble free.[I have over 2400 1/4 miles on the 2 so I speak from experience.]
I now have a 9" and am quite pleased with it,no more concern about the rear at all.
Originally Posted by Z95m6
That info is false. You can have LT1 rears with 3 or 4 channel setups, and LS1 rears with 3 and 4 channel setups. Both LS1 and LT1 rear ends are junk.
i had a 2.73 lt1 rear axle, which is supposed to be really "beefy" because the teeth are the thickest. any way, i have also gotten my hands on a 3.23 from a ls1. this one however was massive, weighed way more, and just looks bigger. i know the dimensions are the same, but i took off the girdle and the insides were just amazing compared to the lt1's. the 3.23 axle had the entire pumpkin of the axle filled with gears and springs and all other kinds of stuff while the lt1 axle just looked weak on the inside. everyone here says that they are the same, well i must have switched from the auburn to the torsen then. either it was that or an aftermarket axle.
10-31-2016 11:09 AM
NewsBot
01-29-2015 07:10 PM
NewsBot
01-11-2015 06:10 PM
NewsBot
12-28-2014 06:20 PM
