I have no overdrive in my 94 cam
So Im new here, due to the recent purchase of a 94 camaro. I love the car, but, Im still trying to iron out some, what I thought to be small, problems. The car is in great shape cosmetically, interior is still mint, body is good, and I have done alot of preventative maintanance on it so far. However, On my way home today, I had the shifter in overdrive, but it never got out of 3rd gear. Shifting through the gears ( 1st to 2nd) it would tach pretty high. 1st gear would tach out around 4000rpm before it shifted into 2nd, and I wasnt on the throttle that hard for that to happen. It shifts into 3rd pretty normally.
I know this tranny has a lock out torque converter system, but can anyone tell me why I have absolutely no overdrive?
Re: I have no overdrive in my 94 cam
What condition is the fluid in? Is it dark or smell burnt? Are you certain it's not making a 1-3 shift? 2 things have to be applied for O/D. the 2-4 band and the 3-4 clutches. Your 1-2 shift issue makes me believe you're experiencing band failure. If it were missing both 3rd and 4th, I'd say the 3-4 clutches. If the trans has any amount of miles on it, I'd say there's a good chance that both are bad.
Frank
Frank
147k miles on it. The only fluid that is not new is the trans. Im going to do a filter and fluid change this weekend. If the issue your talking about w the bands and clutch packs are the case, that pretty much means the trans needs to be rebuilt?
Frank
I dropped the trans pan this morning, there was a little black film on the bottom But I would say not much. Im gonna go refill the pan w new fluid and some Lucas trans additive, and see what Happens....Our Father, who art in heaven hallow be thy name.....
Frank
well that blows. So the Lucas stuff is junk huh? I refilled the trans w new fluid, It did help, however, I still have no overdrive but no more clutch slippage. Maybe this will buy me some time though, until I got the loot to spring for a new trans.
Caps94ZODG
25
10-02-2003 06:30 AM
Caps94ZODG
09-07-2002 10:09 PM
