Car wont shift to second at WOT
Old 06-27-2015, 06:25 PM
Critter's Avatar
Was driving my camaro (see sig) and romped on it. Pulled great, but towards the top end it felt like it stopped pulling, but kept revving up almost like the wheels were spinning. At first I didnt think anything of it because i have drag radials that are pretty worn. But, then i realized that it stayed in a completely strait line while i thought it was "spinning the tires".
So I pulled over, checked the fluid. Amount was right on the money. Got back in and launched it again from first and towards the top end it felt like it was either spinning or almost in neutral and banged the rev limiter 6 times (normally it may hit it once and shifts). I let out and it promptly shifted.
At 80 percent throttle it shifts fine. Holding it steady at 4500 rpm and shifting to second manually it shifts firm and fine as well. No flair shifting and no check engine light.
Critter is offline
Old 06-27-2015, 06:51 PM
Critter's Avatar
Re: Car wont shift to second at WOT
Also i think i noticed a shutter or vibration from under the car while when it was supposed to shift and the cam surge feels worse than normal.
Critter is offline
Old 06-29-2015, 06:58 PM
Scan the PCM. The trans codes don't turn on the SES light.
Injuneer is offline
Old 07-02-2015, 10:10 PM
DelSoto's Avatar
I have heard of that before. Is that what is referred to as 'stall wall'?
DelSoto is offline
Old 07-07-2015, 08:34 PM
Critter's Avatar
i've got a obd 1 connector I just need to find a program and install it now.
Critter is offline
Old 07-07-2015, 10:37 PM
For an OBD-1 scan program, download Scan9495. Sticky at the top of the "Computer Diagnostics......" forum.
Injuneer is offline
Old 07-13-2015, 05:51 PM
Critter's Avatar
Clutches are gone, fluid smells burnt, and clutch material on the rag i checked it with.
Critter is offline
jayblev95
01-20-2015 01:30 PM
97SSdude
12-31-2014 07:43 PM
tds1213
11-27-2014 12:55 PM
USAirman93
11-24-2014 03:37 PM
IgorT.455/406
06-04-2003 03:32 AM
Quick Reply: Car wont shift to second at WOT
