Bolts stuck on bell housing
Old 07-24-2016, 02:02 PM
  #16
Chimera96's Avatar
Re: Bolts stuck on bell housing
if you are putting in a new FW hold off on spacing out the slave...maybe both your low pedal engagement and fork buzzing PP will be resolved with new FW.
If your clutch is worn, replace it also.
Chimera96 is offline
Old 07-24-2016, 04:06 PM
  #17
Bxlt1's Avatar
Good point,the clutch,pp all bearings are new flywheel is???
Bxlt1 is offline
Old 07-24-2016, 04:35 PM
  #18
Chimera96's Avatar
do you have the clutch out now?
how does the TO bearing look?
Old 07-25-2016, 07:06 PM
  #19
Bxlt1's Avatar
Yes had the tranny out for 2weeks and the entire clutch last week all only have 32 miles on it.t.o still looks like the day I got it. I am gonna order a f.w and it does make sense as what you said. I have no idea the age or how many times it was milled before I had it done.
Bxlt1 is offline
Maroz28maro
07-29-2016 07:45 PM
Bxlt1
09-17-2015 08:31 AM
rideordie
09-07-2015 08:22 AM
chevyowner02
08-08-2015 01:38 PM
SergheiS
04-26-2015 08:15 PM
Quick Reply: Bolts stuck on bell housing
