Best differential oil?
Old 02-06-2012, 09:53 PM
mlopezart's Avatar
Hey guys, anyone used Amsoil 75w90 on their LS1's for their differentials? Any help would be much appreciated. Thanks!
mlopezart is offline
Old 02-10-2012, 10:11 AM
Marc 85Z28's Avatar
Re: Best differential oil?
I've never run the Amsoil 75w-90. Just run whatever name brand you can find. Limited slip additive isn't necessary if you've got the Torsen rear differential, but using it won't hurt.
Marc 85Z28 is offline
Old 02-10-2012, 03:54 PM
rv93's Avatar
i use mobil1 synthetic 75w90. its pretty pricey, but since it lasts so long, it worth it to me
rv93 is offline
Old 02-10-2012, 07:06 PM
96 Z 28's Avatar
I run Amsoil Severe Gear 75/90W.
Solved the severe whine in my Diff where I thought the Diff was going to go bad...
I also use their Limited Slip Additive, and it works well.
PS - I WOULD NOT run just any old oil in our Diffs. Our Diffs are pretty fragile due to size as it is, so anything you can do to help out with better oil is going to help.
Preference from what I've seen myself and read, is Amsoil, seems to prevent shear best and maintain it's properties over time much better over time than others.
Gear Lube White Paper from 2007
I'm sure there is some updates since this was done, and Amsoil Haters will come out of the woodwork, but it's not just a ruse. They do make solid products, just not cheap...
EDIT: I also just remembered that they changed the weight specs a while back and some locol folks switched to the 75/110 Weight with more preferring that for it's viscosity ratings
96 Z 28 is offline
Old 02-10-2012, 09:31 PM
96capricemgr's Avatar
Please ask for how people are evaluating.
As noted the Torsen does not need limited slip additive because it is not a clutch posi.
Never seen any 7.5" lube failures so IMO all you are going to get is opinions based on marketing.
Don't get me wrong I have seen the Amsoil gear lube test and none of is surprised me.
It IS a marketing piece but it is still worth looking at. Pretty well known Lucas and Royal Purple rely solely on marketing and put out mediocre products and the testing shows that, but even with those I doubt you would see a lube failure.
96capricemgr is offline
Old 02-11-2012, 08:52 AM
Marc 85Z28's Avatar
That's not possible. You cannot quiet gear whine, much less severe gear whine, by changing gear oil brand
The oil used in the axle will do NOTHING to increase the strength of the components, or to reduce the chance of broken parts.
Old 02-11-2012, 12:03 PM
Maybe the axle was low on oil and getting loud?
Maybe it had the wrong oil entirely in it? I heard a story of someone trying motor oil once and said it was loud.
I agree though, expensive gear oil will not solve a mechanical issue.
Old 02-12-2012, 08:10 AM
Marc 85Z28's Avatar
That's possible. But again, fluid won't fix that! If you begin to hear noise due to a low fluid level, it's rebuild time!
Old 02-24-2012, 11:36 AM
mlopezart's Avatar
Wow thanks for the feedback, everyone. I know I have a Torsen diff, and I read I didn't need the limited slip since Amsoil already has it (or my diff doesn't need it), either way I don't think I need that. I'll be getting 75w110 since my diff whine is getting louder. Man its annoying driving on thefreeway, totally demoralizing since I love the car!
Old 02-24-2012, 12:11 PM
The more you drive it the worse the damage will be.
jl1ne
07-07-2015 08:38 PM
streetbad
Advanced Tech
07-05-2015 10:40 PM
SergheiS
07-05-2015 03:27 AM
Koby
06-28-2015 04:46 PM
FredM
06-05-2015 05:45 AM
Quick Reply: Best differential oil?
