Another Problem
Another Problem
I recently got a 1996 Z28 and two days after i got the car it wouldnt go into gear, so i replaced the clutch, still same problem, so then i replaced the clutch slave and master cylinders, then i couldnt get the car to start, so i realized the not starting problem was that the clutch peddle wouldnt go down far enough to hit the clutch safety switch, so i held the switch down with my hands and had someone turn the key for me, the car made a sound as though either the engine or the trans had gotten tight, anyone have any idea what this problem could be, im running out of patience with this stupid car
thanks
russ
thanks
russ
