99 a4 stock gears
Old 12-23-2013, 04:47 PM
Mr99SS's Avatar
99 a4 stock gears
What gears are best for a4 cars 1/4 ? Car leaves pretty lazy now then picks up good after 2nd
Mr99SS is offline
Old 12-24-2013, 12:25 PM
Kevin Blown 95 TA's Avatar
Re: 99 a4 stock gears
The consensus has always been 3.73 gears perform best for an A4 car, but it depends on what else has been done to it which gear you should go with.
Usually, the cars lose traction in 1st then bog a little in 2nd because of the too low first gear and wide 1-2 gear ratio, so I'm not sure what is going on with yours. These trannies aren't set up very well for a drag race. Then if you go with a lower gear and a converter, you deal with traction problems off the line and still have the less-than-ideal 1-2 shift, although it will be much better since the lower gear ratio will help and the converter will soak some of it up.
Kevin Blown 95 TA is offline
Old 12-24-2013, 03:23 PM
FirstYrLS1Z's Avatar
what's your current gear,2.73(option code GU2) or 3.23(option code GU5) ?
FirstYrLS1Z is offline
Old 12-25-2013, 10:23 AM
Mr99SS's Avatar
3.23 I think not sure 2krpm @ 80mph .its getting a 3500 converter 125 nitrous adj torque arm and 276/6015 mt dr's
Mr99SS is offline
Old 12-25-2013, 10:57 AM
Look for the RPO codes mentioned in the post above. GU2 or GU5. The codes are on the service parts label in your glove box.
Injuneer is offline
Old 12-25-2013, 12:46 PM
2000 @ 80 looks like 2.73s'.
My 3.23s' are 1800 @ 60,2100 @ 70,2400 @ 80.
RPMs were read off a ScanGaugeII and MPH was indicated by a GPS unit.
Can't go by factory tach as they typically indicate too high and who knows how accurate your speedo is.
HectorM52
07-30-2017 11:46 AM
10-31-2016 11:09 AM
jayblev95
Track Kill Stories
01-15-2015 07:48 AM
ddr698
01-09-2015 10:05 AM
cmdeshon
12-27-2014 10:06 AM
Quick Reply: 99 a4 stock gears
