'94 Camaro LT1 Transmission Problem - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 07-10-2012, 09:37 PM   #1
I am new to this site and registered because I've seen a lot of helpful info with some of my problems with this car. My problem now is that the transmission in my 94 Camaro doesn't engine break only in OD. When I manually shift the transmission in 1st, 2nd, and Drive and let off the throttle going down the road the transmission shifts into neutral. When it's in OD it works fine. I have recently changed the transmission fluid in it and I cannot attest to the fact that this problem started when I done that. The computer was also changed in this car a while back and the speed o-meter is 10 mph. I'm just wandering if there is something in the trans going bad or could it be the computer or maybe even changing the fluid. BTW the car has 235k miles on it and nothing has ever been rebuilt...fluids have been changed properly for the life of it. Any help would be appreciated!!
383nova is offline   Reply With Quote
Old 07-14-2012, 08:05 AM   #2
Re: '94 Camaro LT1 Transmission Problem
I can't answer your question exactly because more than one thing could be going on, but I can tell you that DFCO (decelleration fuel cut off) is controlled by the computer and is adjustable for different driving conditions based on mph, rpm, load, and coolant temp. So all of those parameters are considered for whether or not the computer decides to take away fuel and retard the timing to slow the car down or just let it coast. Whether or not you have anything wrong with your transmission - I couldn't say - there are a couple transmission experts on here who might know. If your speedometer isn't reading correctly, it is possible your computer isn't calibrated to the gears in your rear end - and that wouldn't help matters, either. And if that is true, who knows what else isn't correct in there.
Kevin Blown 95 TA is offline   Reply With Quote
Old 07-14-2012, 02:49 PM   #3
I thought that was normal. My Z28 has always done that. In overdrive, your converter is in lockup mode. But then again, I am not a transmission man, so who knows?
Joe p is offline   Reply With Quote
Old 07-17-2012, 09:49 AM   #4
Old 07-17-2012, 01:27 PM   #5
Super Moderator
And the reason for the second post is?
Injuneer is offline   Reply With Quote
Old 07-17-2012, 01:39 PM   #6
To see if anyone was reading it. Thanks
Old 07-17-2012, 05:41 PM   #7
Super Moderator
Not a lot of traffic on this forum. But there are a couple knowledgeable people who show up once in a while. Generally worth waiting for.
Old 07-17-2012, 06:03 PM   #8
Quote:
Thanks for the response, I can tell you this, my mechanic put a new computer in it and optispark distributor at the same time and ever since then the speedometer has been off (bout 10-12 mph faster than what you actually are driving) Im guessing it needs to be calibrated....?
Old 07-31-2012, 06:55 AM   #9
12SCNDZ's Avatar
The lugs are broke off the over run hub part of the input sprag. I've seen this happen quite a bit.
Frank
12SCNDZ is offline   Reply With Quote
Old 08-03-2012, 06:51 AM   #10
Thanks! Now I know.
Old 10-26-2012, 09:14 AM   #11
Had the transmission rebuild. Works great now. It was only $1759.
Reply
Thread Thread Starter Forum Replies Last Post
1969 Chevrolet Camaro Collector Car Cars For Sale 0 12-17-2014 02:12 PM
odds and ends CaRParts102 Parts For Sale 0 12-06-2014 09:45 AM
cant find OEM Pos battery cable/ auto tran selector lever Sarahrope64 LT1 Based Engine Tech 0 11-27-2014 12:17 PM
hey hey hey thenewkid New Member Introduction 5 11-27-2014 10:41 AM
*excellent info* 93 specific info list. chevroletfreak LT1 Based Engine Tech 202 07-04-2005 06:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
