9 inch owners with stock driveshaft PLEASE HELP! - CamaroZ28.Com Message Board
Reply
LinkBack Thread Tools Search this Thread
Old 10-07-2004, 07:58 PM   #1
Here the deal, I'm getting ready to install my moser 9 inch this weekend and wanted to use the stock drive shaft.
I've done a bunch of searching and come across a few guys who have but I need some part #s and some one to confirm what I need. I've heard that a U joint from an old Faraline will work because its longer.
I do plan to have one made over the winter, but right now I just want to use the stocker if it doesn't cost too much to convert the drive shaft.
If any one could help me out it would be greatly appreaciated
97pontta is offline   Reply With Quote
Old 10-07-2004, 09:47 PM   #2
Re: 9 inch owners with stock driveshaft PLEASE HELP!
i have a ford 9" with the stock drive shaft and stock u-joint, if you look you can find that ford makes a 9" yoke that uses the same size u-joint as the factory gm
jay_lt4 is offline   Reply With Quote
Old 10-07-2004, 09:54 PM   #3
I've already got the billet yoke that came with the moser rear, I really didn't want to change the yoke on the rear. Was the different GM yoke longer to make up for the need of a longer drive shaft.
I'd like to use my stock driveshaft without modifying the length, just the rear u-joint if at all possible.
Old 10-07-2004, 10:26 PM   #4
yup ford makes a 9" yoke that is longer and uses the same large u-joint as chevy it works perfect with the stock drive shaft, i dont know what ford vehicles they came on stock, i have an extra one here that i might part with for the right price,, i found it at a swap meet and bought it for an extra for my car
Old 10-07-2004, 10:43 PM   #5
n2ceptor's Avatar
Have you tried contacting Moser for the proper U-joint to use??? Or you can take the Yoke and the stock u-joint to a parts store and have them match it up...
n2ceptor is offline   Reply With Quote
Old 10-07-2004, 10:53 PM   #6
I havn't started the install yet, I'm just trying to get a game plan.
So, If I get a different yoke for the rear, Is there any problems with removing the yoke and distrubing the gear set? I just don't want to damage or mess with the pinion gear depth.
Sorry for all the questions...
Old 10-08-2004, 02:03 AM   #7
nope, just replace the yoke, just dont over tighten it and you would be fine,
on my car if i used the small short ford yoke and the stock driveshaft i came up a bit short, not enough of the yoke in the trans
so i found the large long ford yoke's and it worked out perfect with the stock u-joint and drive shaft length
Old 10-08-2004, 11:59 PM   #8
my moser has the 1350 yoke. I bought a Precision 447 u-joint from summit racing to put in my stock driveshaft until the Denny's Nitrous ready one gets here. It fit perfectly.
Roadie is offline   Reply With Quote
Old 10-09-2004, 12:03 AM   #9
OBE1 95Z28's Avatar
Removing the yoke may or may not affect your pinion preload. My 3rd member was built with a solid spacer so I'm able to remove the yoke. Some 3rd members use a crush sleeve to set the pinion preload; removing the yoke would affect the preload. You need to check with the builder of your 3rd member.
I had to go with a shorter driveshaft with my Moser 9"; I have a M6 though.
OBE1 95Z28 is offline   Reply With Quote
Old 10-09-2004, 12:55 AM   #10
Quote:
So your using your stock driveshaft with that u-joint. There was no issues with the length of the driveshaft?
Thanks for all the help guys!
Old 10-09-2004, 01:43 AM   #11
IllusionalTA's Avatar
need a 1310-1350 U joint! best bet is to goto a Driveshaft shop.. Autozone is really useless when it come's to this stuff.. Napa's tend to be pretty good w/ their knowledge so you can try them as well.. i have a stock driveshaft as a spare in case i snap any more.. From what i hear its a 3rd Gen Ujoint.. But i can't confirm!.. bring your yoke w/ ya if you can..
IllusionalTA is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Getting Out of the LT1 Game - LT1 Engine Parts HectorM52 Parts For Sale 25 09-06-2016 07:44 AM
OEM 94-LT1 cam 45K nice cond make offer canbaufo Parts For Sale 7 05-25-2015 01:01 PM
Custom driveshafts, more driveshafts, and then some more driveshafts ddr698 Parts For Sale 3 01-31-2015 11:58 AM
putting a big block in a 3rd gen 89 iroc zl1 3rd Gen / L98 Engine Tech 0 01-14-2015 03:18 AM
[Michigan] Clean 96 Caprice Classic for sale BIGCOWL-IMP Midwest 0 11-21-2014 10:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 1996-2013 CamaroZ28.Com. All rights reserved.
