4L60e Transmission swap guide
I had a question about swapping a trans from a '94 into my '95 and the impalassforum was down...I guess no one here knew the answer. Now the site is back up, I figured I'd spread the info...enjoy.
A what-body? - refers to the GM vehicle "platform": (relevant years are included)
B-body: Chevy Caprice, Buick Roadmaster, Olds Custom Cruiser
D-body: Cadillac Fleetwood (1993-1996)
F-Body: Camaro & Firebird (1993-2002)
Y-Body: Corvette (1992-1996)
4L60E similarities:
All 4L60E/4L60/700R4 have the same gear ratios which cannot be modified:
1 - 3.06:1
2 - 1.63:1
3 - 1.00:1
4 - 0.70:1
GM B and D-body 4L60E differences by year:
94: First year of electronic controls in the valvebody (versus the 93 4L60, which did not have this). The PCM controls line pressure (holding power and shift feel), 1-2, 2-3 and 3-4 shift points (rpm), and TCC lockup (timing and in the 95-up models, apply feel). Everything else is done mechanically/hydraulically.
95: Added a Pulse-Width Modulation Torque Converter Clutch (TCC) apply solenoid to control the feel of the TC clutch lockup (blamed for many 4L60E problems; TransGo HD2-C bypasses this, or you can stake the TCC apply valve in place). Also changed 3-2 downshift solenoid mid-year (see '96, below).
96: PWM TCC plus a different tailhousing design with new-style Vehicle Speed Sensor (VSS). Also changed the 3-2 downshift solenoid in mid-1995 from TBD to TBD. There was a new manual valve added along with a relief port over the manual valve on the valve body casting with this change. This solved the low/reverse clutch release problem and makes the TransGo manual valve mod unnecessary.
How to visually tell B and D-body transmissions apart by year:
'94: VSS on driver's side of tailshaft housing, and when you remove the torque converter, there is no "PWM" on the front surface of the pump. In the pan, only one solenoid on the front face (relative to the transmission in the car) of the valvebody.
'95: VSS on driver's side of tailshaft housing, and when you remove the torque converter, there is "PWM" in raised letters on the front surface of the pump. In the pan, there are two solenoids on the front face (relative to the transmission in the car) of the valvebody.
'96: VSS on passenger side of tailshaft housing, and when you remove the torque converter, there is "PWM" in raised letters on the front surface of the pump. In the pan, there are two solenoids on the front face (relative to the transmission in the car) of the valvebody.
9C1 Trans differences:
9C1 4L60Es come with a 1st gear lockout function that is a tab secured next to the shift linkage by the oil pan bolts. This can be removed by removing the two bolts and then reinstalling and torqueing them to 9ftlbs.
LT1 vs. L99 Trans differences:
4L60Es in L99 4.3L V8 cars come with a smaller servo than the LT1 5.7L V8 cars, which come with the cor-vette servo for more holding power on the 1-2 and 3-4 shifts. If an L99 4L60E is going behind an LT1 engine, the servo assembly should be swapped over before installed (easily accessible on the passenger-side of the case). TransGo also sells a vette servo that can be installed as part of their 4L60E HD-2C reprogramming kit. Also, the boost valve is smaller (again, Transgo fixes), and it is possible that some holes in the separator plate are smaller.
Cadillac Fleetwood V4P differences:
Cadillac spec'd the Fleetwood towing package (V4P) to tow up to 7000lbs. The transmission was setup from the factory to shift a bit firmer. If you swap one of these transmissions into your car, be careful how line pressure you add in via the PCM. Each vehicle and package generally had some small tweaks (L99 vs. LT1, truck vs. car), so be aware that the shift feel will probably not feel the same after a swap.
Can I use a 4L60E from a...?
Note: This info assumes you can swap or remove cooler line fittings, electronics modules, tailshaft housings, and shifter brackets yourself.
1. CK Truck or Fullsize Van: Any "K" case out of a '94-97 GM full-size 2WD pickup will work. 4WD transmissions have shorter tailshafts which cannot be swapped without disassembly. 4L60Es behind the 305 V8 and 4.3 V6 came with the smaller '..553' servo which should be replaced with an '..093' "corvette" servo. Other V6 versus V8 internal differences are unknown.
2. S10/Blazer (2WD V6 only): Probably. 4L60E was used '93 up to '96???. You will need to swap the servo assembly out of your b-body 4L60E (make sure to put a new blue o-ring on the servo cover when you do so). Other mounting, electrical and internal differences are unknown at this time.
3. F-body (Camaro-Firebird) LT1 4L60Es from '94-00 will fit. They also have the "corvette" servo. LS1 4L60Es from '98 up will bolt on but you must use the LS1 torque converter. Unknown as to whether the LS1 TC will bolt to an LT1 flexplate. V6 transmisssions have incompatible bellhousings and will not work.
4. Corvette 4L60Es from '94-96 are identical internally (and obviously have the "corvette" servo). The difference is the case. It will be impossible to bolt the exhaust hanger bracket to the case without modification to the vette case.
Can I use a 4L60 or 700R4? from a '91-93 Caprice or other vehicle?
Don't bother. You could, but it's not worth the effort. The internal rotating parts are basically identical but everything else is different. Sell it and get a 4L60E.
Caprice Transmissions from '8x-96:
198?-1990 - 700R4 (also 200-4R on some models)
1991-1993: 4L60
1994 - on : 4L60E
Year to Year B/D-body Swap Guide:
To put a 94 4L60E into a 95 car: Direct bolt-in; no mechanical or electrical changes required. The PCM must be reprogrammed with 94 transmission base code to avoid setting a silent code (Check Engine Light (CEL) does not illuminate, but code stored in memory). Trans will operate normally without reprogramming.
To put a 94 4L60E into a 96 car: The 96 tailshaft housing and VSS must be installed on the 94 4L60E before the trans can be bolted into the car. No other mechanical or electrical mods necessary. The PCM must be reprogrammed with 94 transmission base code to avoid setting a silent code (Check Engine Light (CEL) does not illuminate, but code stored in memory). Trans will operate normally without reprogramming.
To put a 95 4L60E into a 96 car: The 96 tailshaft housing and VSS must be installed on the 94 4L60E before the trans can be bolted into the car. Technically, the 3-2 downshift solenoid should be swapped also, but experience shows that it is not required.
To put a 95 4L60E into a 94 car: No mechanical mods required. Mod A must be performed. The trans will operate normally without Mod A but TCC lockup will not work, so highway and cruising gas mileage will suffer and more heat will be produced in the transmission.
To put a 96 4L60E into a 95 car: The 95 tailshaft housing and VSS must be installed on the 96 4L60E before the trans can be bolted into the car. Technically, the 3-2 downshift solenoid should be swapped also, but experience shows that it is not required. No other modifications are necessary.
To put a 96 4L60E into a 94 car: The 94 tailshaft housing and VSS must be installed on the 96 4L60E before the trans can be bolted into the car. Mod A must be performed. The trans will operate normally without Mod A but TCC lockup will not work, so highway and cruising gas mileage will suffer and more heat will be produced in the transmission.
Mod A (method 1):
An additional wire must be run from the PCM pin TBD to pin TBD on the trans harness for the TCC to work. Also, the PCM must be reprogrammed with 95 transmission base code.
Mod A (method 2):
Swap the 94 internal harness into '95-96 transmission, leave PWM solenoid unplugged but installed. On the valve directly to the right of the PWM solenoid push that valve all the way towards the outside of the valvebody , push it against the side of the valvebody and stake it into place. Thatll lock down your PWM function and itll function like a regular lockup. No PCM reprogramming required. Now with pics!
4L60E similarities:
1 - 3.06:1
2 - 1.63:1
3 - 1.00:1
4 - 0.70:1
1991-1993: 4L60
1994 - on : 4L60E
Mod A (method 1):
Mod A (method 2):
i am putting a 6.2l diesel in an 03 Astro..... thats right i said Astro... lol.. it has 2" frame spacers and HD varible coil springs so i do nt think clearance or weight is an issue... but the tranny and coolind that big boy might.... looking to use the 4l60e but i don't know what all is needed to convert to a 700r4.... would you have any idea what other problems i might have with my Astro HD project
Re: 4L60e Transmission swap guide
4L60E similarities:
1 - 3.06:1
2 - 1.63:1
3 - 1.00:1
4 - 0.70:1
1991-1993: 4L60
1994 - on : 4L60E
Mod A (method 1):
Mod A (method 2):
4L60E similarities:
1 - 3.06:1
2 - 1.63:1
3 - 1.00:1
4 - 0.70:1
1991-1993: 4L60
1994 - on : 4L60E
Mod A (method 1):
Mod A (method 2):
If you are asking specifically about a 95 4L60E in a Camaro with a 94 PCM, there are issues involving wiring, and switched converter lockup vs. pulse width modulated lockup.. Read this:
4L60E year differences and interchanges.
Be sure to read all the way to the “Additional Information” at the bottom.
Just an FYI - all 95 LT1 F-Bodies are OBD-1 PCM with the 16-pin OBD-2 DLC. And 94 and 95 PCM part numbers are the same. Only the programming is different - in this case with regard to converter lockup strategy. There are no “early 95” vs. “late 95” differences.
ninety4formula
07-23-2007 08:00 PM
