4l60E late shift
Old 09-15-2016, 12:38 AM
Gasmachine85's Avatar
4l60E late shift
When at wot my car will hit the rev limiter before shifting. It's so bad that it usually will not shift into 3rd. Any ideas?
Gasmachine85 is offline
Old 09-15-2016, 12:46 PM
Re: 4l60E late shift
Please add details of your car - year, model, engine, trans, any major modifications.
Injuneer is offline
Old 09-15-2016, 03:07 PM
1995 z28 lt1 4l60 k&n cai everything else is bone stock. Trans was rebuilt about a year ago but don't know much else about it.
Have heard the tv cable can effect this so I'm going to look into that but otherwise don't know how to fix it other than commanding it to shift in the tune.
Old 09-15-2016, 07:55 PM
There is no TV cable on an electronically shifted 4L60E (1994-2002). Only the non-electronic 4L60 (aka 700R4) used in 1993 needs the TV cable.
If you have access to an OBD-1 scanner, there are codes for the trans that do not turn on the SES light. See Shoebox's LT1-specific code list. OBD-1 trans tab is at the bottom of the page.
http://shbox.com/1/Dtcs.htm
Injuneer is offline
Old 09-15-2016, 08:48 PM
Super Moderator
JakeRobb's Avatar
First things first: have you checked the trans fluid level?
JakeRobb is offline
Old 09-15-2016, 10:06 PM
You know, I actually have not, mostly because I have not had a day off since I bought the car. I havnt even driven it much yet tbh. This weekend is my off weekend so I plan on getting well acquainted with it this weekend.
I'll probably have some newbie type questions for a little bit just because I'm not familiar with the 93-97 platforms so bare with me but I'll give it a check tomorrow. Would be nice if that's all it is though, lol I'm currently looking for a good used laptop so that I can get tunercat.
Old 09-16-2016, 02:23 PM
Update trans fluid level is on point.
Old 10-20-2016, 03:57 PM
12SCNDZ's Avatar
If this issue has just appeared without any changes to the vehicle, it's most likely the 3-4 clutches starting to go. GM didn't do us any favors with the 4L60E as far as the 3-4 clutch. There are no less than 6 different changes/upgrades/modifications we have to make to get them to stay alive. What you're most likely feeling is a longer apply time, due to wear. This delay in apply will allow the engine to hit the limiter becore the shift is allowed to complete.
Frank
12SCNDZ is offline
Old 10-25-2016, 11:26 AM
Super Moderator
JakeRobb's Avatar
Frank!
Haven't seen you around here in years. Is CPT still in business? I seem to remember some sort of family issue pulling you away some years ago, but I could easily be misremembering or misattributing.
JakeRobb is offline
Old 10-25-2016, 03:04 PM
12SCNDZ's Avatar
Frank!
Actually, I went through some health issues several years back. I took a couple years away from CPT during that time, but I've been back at it for over 5 years now. We've restructured many things since that time. Back then, CPT was being ran as a side business in tandem with my 40 hour a week job, building for another local shop. That's all changed and CPT is a full time shop now. Business has been beyong belief and we've got a lot of great things going on here.
Frank
12SCNDZ is offline
dandick
10-05-2016 08:24 PM
Stealth_Z28
09-30-2016 01:47 AM
real82it
09-24-2016 08:00 AM
NewsBot
09-09-2016 10:00 AM
lovemyblackz28
09-06-2016 09:25 AM
Quick Reply: 4l60E late shift
