2800-3000 stall with OBD1 pcm??
Re: 2800-3000 stall with OBD1 pcm??
I say its a crap shoot! You might ....you might not
My 95 has issues with the 3000 stall. I did not notice it after the cam and heads but when i replaced the fuel pump and injectors because it was starving for fuel .........thats when it happened. Steven
The stall will depend on how much power you make. Mine had the common problem..... at the track after stalling it up on the line it would not shift into second and bounce off the rev limiter then go into limp home mode. It actually felt like it left the line in second.On the street it was fine. If you make enough power for a 3000 stall to stall at 3000 then you may have problems.Their are programmers that have a fix for it if you do such as PCMforless. Steven
whitehooptie
08-10-2015 07:02 AM
detroitmuscle
07-31-2015 04:21 AM
88IROC_Z
07-22-2015 11:38 PM
