1996 z-28 rear end clunk
Old 08-26-2016, 08:57 PM
joepin's Avatar
96 z-28 auto trans low speed rear end clunk,clunk ,start off with a little gas you dont hear it . 97,000 miles what could it be ? thanks
joepin is offline
Old 08-28-2016, 06:52 PM
Super Moderator
JakeRobb's Avatar
Re: 1996 z-28 rear end clunk
Check attachment points of the torque arm, sway bar, panhard bar, shock mounts, everything you can think of back there.
JakeRobb is offline
Old 08-28-2016, 07:11 PM
You sure it's at the rear of the car, and not a broken trans mount allowing the trans to lift and hit the floor under torque arm loading?
Injuneer is offline
Old 08-29-2016, 06:43 PM
joepin's Avatar
if it ever stops raining here in florida i will check it all out thanks for the hints
joepin is offline
Old 09-03-2016, 10:02 PM
Super Moderator
JakeRobb's Avatar
Fred, if I'm not mistaken (or maybe I'm misreading Joe's post), wouldn't a broken trans mount make a louder, more noticeable sound if you hit the gas hard?
JakeRobb is offline
Old 09-04-2016, 07:58 AM
Yes, but the way I read it I interpreted "start off with a little gas you don't hear it" as meaning you only do hear it when you go hard on the throttle. Maybe I read it wrong..... I don't know.
Injuneer is offline
CamaroSS30thAnn
09-08-2015 04:43 PM
Tudds
07-17-2002 02:20 PM
FTLBS
06-21-2002 05:46 PM
4ssFed
06-11-2002 06:46 AM
Quick Reply: 1996 z-28 rear end clunk
