1993 camaro z28 best clutch for street
hello guys, i have a 1993 camaro z28 with M6 transmission, i am planning on changing my clutch, but i dont know which clutch is the best clutch for street driving, my car has minor mods, and planning to add more in the future, but mainly for street driving. i am planning on changing my rear differential gear ratio with it too, so any ideas on what is the best clutch, gear ratio combination for street driving.
Re: 1993 camaro z28 best clutch for street
I like the centerforce DF clutch...its worth every penny I spent on it
I am from SE MI also, most reputable shops will have no issues performing a clutch job and if they have experience with GM rear diff, they should have no issues setting up a new ring and pinion. There is nothing exceptionally special about it, just need to find the right mechanic.
I went with a McLeod RST twin-disc clutch. It cost under $800 from Amazon. It's good for up to 800hp (more than I'll ever have) and offers stock-like pedal feel. Any single-disc clutch that holds more power than the stocker is going to give you a stiffer pedal too.
I also upgraded to a lightweight flywheel. I went with a 15lb forged steel unit from ACT - it was under $300 (Amazon again). I strongly recommend going to a lighter weight flywheel. It significantly increases the fun-to-drive factor IMO.
I've had work done by White Racing and Marine out of Warren. They're a good shop and they don't overcharge.
Brandon Wittmer
12-03-2014 09:28 PM
2000silverz28
07-20-2002 06:14 AM
