What's your trap RPM ?
#16
Here is my $.02. What RPM are you currently crossing the finish line? I would say you are looking to cross at 6000 rmp. Bolt-ons will change the results (gears, tire diameter, converter, headers, shift points, etc).
In my 95 Formula convert, stock, auto, 2.73 gears, 26" diameter drag radials. I bumped the 1-2 shift point up to 50mph and moved the rev limiter to 6200rmp. I was able to cross the finish line in 2nd gear at 6000rpm. I was able to duplicate this in a 95 Formula hardtop.
I have another formula , 383lt1, turbo 400 auto, 27" diameter tires. I have changed gears and tires to get the finish line rpm desired. Nothing like spending $$$ to have gears installed only to have the work redone the following week. I made the mistake of changing gears and tire diameter at the same time. Duah, make only 1 change at a time.
1" change of tire diameter = one jump in gear ratios
26" diameter tires and 3.73 gears = 27" diameter tires and 4.11 gears
I would do the boltons first then see where you at rmp wise. Then make addjustments via tire diameter and gears.
#17
My first (ever) three passes last night: The shift light came on in third right before the trap. I had enough tach left to roll thru. Stock gearing, obviously. So about 6500rpm.
#18
I tried that once, the car nosed over when it hit the rev limiter about 30ft before the finish line
#19
#20
My goal is to put in a set of 3.73 gears and then add enough power to max out 4th (~125mph).
#22
You want to be on the limiter in 4th gear with an M6, 3rd gear with an A3/A4. I would absolutely pull 4th gear at the 1000 ft mark if I were at my shift point. However, that simply means that you are grossly under-geared for the 1/4 mile.
#23
3.23 - 153 mph
3.42 - 145 mph
3.73 - 133 mph
3.90 - 127 mph
4.10 - 121 mph
4.30 - 115 mph
4.56 - 108 mph
Yeah, that's because it's (mostly) stock. I'm just working with what I have until I can afford to do something about it.
#26
I believe Warren Johnson once said, "red-line + 5% at the stripe!" Therefore, you should work backwards from that goal (trap RPM), selecting your gears and slick height that will place you there (your red-line + 5%).
With my LTX Camaro I’m turning 7K+ at the stripe with 127 MPH.
WD
WD
#28
#29
Tricky bracket racers there. Her crew chief may have instructed her to short shift in order to slow the ET down a bit. Gives a high MPH to ET ratio for a top end advantage.
#30
