What type of race harness do I need for my set-up
Old 11-14-2006, 12:29 PM
detroit1994z28's Avatar
I have a 94 z28. I just bought a wolfe 6 point bolt in roll cage. I wanted to buy some 5pt simpson race harness belts. I noticed that they sell allot of different styles. I'm not sure what Style that I need. I basically just want the style that bolts in the factory locations and wraps around the roll bar in back. I'm also using the stock seats. Does anyone know a part # or harness that would work. I wanted a 5pt. simpson harness.
detroit1994z28 is offline
Old 11-14-2006, 10:21 PM
Stephen 87 IROC's Avatar
If you need a dated harness, don't get hung up on brand names since you'll need to buy a new one every 2 years. Most of the manufacturers won't even recertify they're own belts any more. The "4 year" platinum belts still need to be returned after 2 years to be updated only the one time. After 2 years of use, most belts need to be replaced anyway from the wear and tear on the cinch points.
Just about every harness can have the lap belts attach the the factory mount points. The crotch belt still needs to attach to the floor under the back of the seat. Many brands offer the wrap around shoulder harness straps since it's cheaper to make than a belt with mounting tabs. Most people who'll be using a 5 point harness have a racing seat and the shoulder belts go through the seat. The easiest way to attach them to the crossbar is a wrap around design.
Now if you're running slow enough where you don't need a dated harness, buy whatever you like since you can keep it in the car as long as you want.
I buy new belts every 2 years and sell off my old ones for about half the cost of the new ones.
Stephen 87 IROC is offline
Old 11-14-2006, 11:07 PM
xpndbl3's Avatar
what is the ET/MPH that you need a dated harness? Mine are out of date and no one has ever questioned the dating on them.
xpndbl3 is offline
Old 11-15-2006, 12:22 AM
Moderator
AL SS590 M6's Avatar
If you have them in the car to use at the track they must be dated. Your track must really be lax because I always get checked.
AL SS590 M6 is offline
Old 11-15-2006, 07:32 AM
The Engineer's Avatar
I live in the Oklahoma City area and home of Stroud Safety equipment (see their add in the NHRA National Dragster). Stroud will inspect and recertify your harness for you every two years. Great company and NHRA supporter.
Yes it is an NHRA requirement for the harness to have a date certification, not greater than two years.
WD
The Engineer is offline
Old 11-15-2006, 08:48 AM
quickSS's Avatar
Originally Posted by The Engineer
I live in the Oklahoma City area and home of Stroud Safety equipment (see their add in the NHRA National Dragster). Stroud will inspect and recertify your harness for you every two years. Great company and NHRA supporter.......................WD
Let me add, Stroud Rocks!! For $25 bucks (or was it $50?) Stroud will reweb your harness. Simpson and others probably do it for a nominal fee too.
But to the question. There are so many options for roll bar attachement that I always call and get the part number directly from the manufacture. Call Simpson directly. They know exactly what questions to ask and what harness you need.
Karl
quickSS is offline
Old 11-16-2006, 12:36 AM
According the the rules, if your car requires a roll bar, the harness needs have a valid SFI date. ie, 11.50 and quicker.
Now a 12 or 13 second car does not require a roll bar and if you put one in, technically the harness can be expired because it's not a requirement. It all depends on your local tech inspectors and how they interpret the rules.
Old 11-16-2006, 02:32 PM
sseeya's Avatar
Call these guys!
http://www.stroudsafety.com/RestraintSystems.html
Since you are using the stock seats, you will probably want to use the standard individual, wrap around style belts. If your budget allows, I would recommend the Kam Lock style. Since Stroud will recertify their belts it's worth it to spend a little extra for the Kam Lock. IMHO
sseeya is offline
Old 05-12-2009, 10:16 AM
James Montigny's Avatar
WD
Which part number do you order ?
Their catalog is confusing for us first-timers.
I'd like wrap-around shoulder/submarine and bolt-in waist with a camlock.
James Montigny is offline
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
CARiD
04-08-2015 08:08 AM
jbrockwell
03-14-2015 08:44 PM
01-05-2015 07:14 PM
Quick Reply: What type of race harness do I need for my set-up
