valve stems?
Old 05-12-2009, 08:25 PM
jonesy's Avatar
valve stems?
saw in NHRA rule book that if you run 11.99 or quicker you need screw in valve stems. is this something new or have they been overlooking that when i'm teched?going on Pinks Allout soon and was wondering about switching them
jonesy is offline
Old 05-13-2009, 12:09 AM
Stephen 87 IROC's Avatar
It's been a rule for many years and is a common item missed on most tech inspections because of where it is in the rulebook.
All tubeless tires must have metal screw in valve stems if running 11.99 and quicker.
Most tire shops should have metal valves stems in different sizes and lengths. The valve stem is a 2 piece design and you must break the bead of the tire to install them. The main part of the stem goes through from the inside with a rubber seal around the stem. On the outside is a nut and rubber seal that screws down on the stem, holding it in place.
You're after something like this which I pulled the picture from Jegs
Stephen 87 IROC is offline
Old 05-13-2009, 04:32 AM
jonesy's Avatar
thx
jonesy is offline
RUENUF
03-13-2016 03:37 PM
350350
14
08-11-2015 12:03 PM
96SilverRam
08-09-2015 04:15 PM
RX Speed Works
07-24-2015 02:25 PM
HectorM52
Parts Wanted
07-19-2015 08:55 PM
Quick Reply: valve stems?
