Questions about Summit's economical race seats?
I saw these seats, part number SUM-G2100.
Do any of you have these installed in your 4th gen Fbody?
What are your impressions of them, I like the price of 40 buck a piece.
I know I need to buy the brackets too, but still, it is within my budget.
Any pros or cons, or problems with installs.
Also if you do have these seat, how much do they weigh?
Peace.
Peace.
I have them,and they are @ 11 lbs with covers.
Pro's are they are light and arent bad for quick trips. Con's are they arent SUPERcomfy,and tend to get a lil rough on long trips. I can deal with em just fine.
There are pics in the second link in my sig.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Dirk
1997 TA A4
The RacinLT1
RacinLT1 pic's
<font face="Verdana, Arial" size="2">Originally posted by RacinLT1:
</font>
</font>
I don't know for a daily driver who good will it be though.
1993 Z-28
13.7s@99.97mph (CAIs and Cut-out)
Hooker Lts => Custom "Y" pipe with two cats, e-mail for pics, (It's possible! )
Lt-4 Hot Cam, 1.6rr, and springs (Crane Cam lifters)
new times coming soon!
http://www.tereschubert.com/camaro
(site needs update for cam and headers)
Only problem I know of as far as fitment goes I dont think the brackets will work. I know I had to make brackets that mounted the seats in a stationary position. I really think theyre not too bad for comfort, but I wouldnt be taking any long trips with them.
1987 GTA- TH400 w/brake, 355, carbed, 11.3:1, TFS twisted wedge heads (non ported), Big Shot NOS, Lunati hyd roller .510/.525 lift 232/242 duration @.050, true dual 3" exhaust, hooker super comp 1 & 3/4" headers, flowmaster 2 chamber mufflers, no tailpipes, 6-pt roll bar strange 12-bolt w/ spool and 33 spline axles, BMR anti-roll bar, BMR LCA relocation brackets, BMR solid rod end panhard bar, PA tubular k-member and a-arms, PA coil over conversion, PA manual rack conversion, Weld Pro-Stars 15X10. Gonna try to fit 29.5X10.5W ET Drags out back, 15X3.5 up front
Best ET last year N/A,Stock suspension, on street tires, T56, stock rear end and 4.56's @ 3515 lbs: 12.44@115.1 (1/4) 8.15@90.5 (1/8)
drive it like you stole it!!
Same here not to bad on short trips but u will need custom made brackets for the seats i had a local chassis shop install the both seats and both 5 point harness for 150 dollars and thats on the high side im sure u could get just the seats mounted for around 50 buck or so.
I had a Jaz bucket in my car for a short while(same basic seat). It was only comfortable for short trips. It was very light. I had to make my own mounting brackets for it.
I wouldn't put one in a car that I was going to drive for any kind of distance.
Tom
1997 30th Aniv. SS <<383 Cubes of Nitrous Huffing Power!
2FASST.com <<< Holy s***! It's really here?!?!
Motown Muscle <<< Dedicated to today's musclecar!
2002 Ford F250 Powerstroke diesel. More torque than my racecar!
"...Now go away, or I shall taunt you a second time!"
Tom
Then a good question is what is the most comfortable seat that weighs the least?
1996 Z28 Camaro
2001 best 1/4 BFG DR's NA - 11.865@113.57 w/1.634 60', 1/8 - 7.563@89.82mph Best 1/4 MPH 114.82 - Best 1/8 MPH 90.73 - 2002 Mid 11's NA, Mid 10's n2o
1989 GMC 1500 truck for work 18.1@73 305
8 cats to feed clean after 1999 V6 Mustang 5 speed
15.358@89.47 MPH w/ 2.227 60'
15.364@90.92 MPH w/ 2.383 60'
My Z28
1996 Z28 Camaro
My Z28
Yes, that would be the best route, I would be willing to pay a bit more for a seat that would be a bit more confortable and still weigh close to these. However, I do not want to pay well over $100 each.
Lalo's 95 TA Homepage
"It will never be fast enough."
If you want to stay around $100, than the choice is pretty much a Jaz/Jegs/Summit plastic bucket. They end up being right at that price when you figure in the mounting-bracket and cover.
To get the same weight-savings, along with comfort, you're gonna spend a LOT more.
Tom
Tom
01-23-2015 01:13 PM
