quarter mile time for stock lt1
Old 03-27-2009, 08:43 AM
  #16
tanks14's Avatar
i just ran mine last week, a4 with 323 gears and i pulled a 14.15 @99.03 with a .4 rt
tanks14 is offline
Old 03-30-2009, 10:01 PM
  #17
Gtpguy's Avatar
14.3@95 with ET streets on a hot October night. 2.2 60ft. Too sticky of a tire thats for sure.
Gtpguy is offline
Old 04-13-2009, 07:23 AM
  #18
my94blackz's Avatar
Originally Posted by Chevy85
Depending on your R/T and your shifting you should be able to pull close to 14 flat all day. Getting a number from us gives you something to base off of but all of the variables at the track will determine everything.
I bet my bolt on auto vert would run a 13 flat with a 10 sec. R/T
my94blackz is offline
Old 05-01-2009, 04:33 PM
  #19
EnFuegoZ28's Avatar
I ran a 14.3 @ 97.4 mph with a 2.24 60ft on street tires. The DA was ~2300. My run with the DA corrected would have been 13.91 @ 99.7mph.
EnFuegoZ28 is offline
Old 05-06-2009, 11:08 PM
  #20
6SpdLT1Z's Avatar
I'd be pretty content for bone stock. Now it's time to get to modding and get deep into the 13's.
6SpdLT1Z is offline
Old 05-09-2009, 07:58 PM
  #21
budgetlt1's Avatar
i'd be happy with a 13.5 or less. i'll find out this friday-its our first test n tune of the year.
budgetlt1 is offline
Old 05-16-2009, 03:36 AM
  #22
budgetlt1's Avatar
ok i just got home, i got 3 passes i rana 13.8 at 101, 13.7 at 102 then a miserable 14.2 at 102 but with a 2.655 60 ft. my best 60 ft was 2.086???
i have mt et streets set at 20 psi but i still spun-and thats after a pretty decent burnout. also i noticed when launching my brakes wouldnt hold the car so i ended up red lighting twice. this car pulls hard and if i can get my 60 ft down, i should see low 13's right?
Old 05-16-2009, 07:22 AM
  #23
Moderator
AL SS590 M6's Avatar
If you're spinning ET street radials you need to look at modding your rear suspension and loosening the front.
AL SS590 M6 is offline
Old 05-16-2009, 12:30 PM
  #24
budgetlt1's Avatar
yeah, thats next on my list. also they are not radials they are et streets with tubes-they should hook great so it has to be my suspension. what do you suggest? its all stock right now.
Old 05-17-2009, 10:59 AM
  #25
Retired
Kraest's Avatar
If you're spinning ET Streets with a bolt-on LT1 car, either your posi is gone or the track isn't prepped worth a crap...or there's water all over the track. I've seen stock suspended cars spray 150 shots out of the hole without spinning. Something's seriously wrong with that. Your car shouldn't be able to turn over 275/40/17 Nittos at that power level when heated up.
Kraest is offline
Old 05-17-2009, 06:05 PM
  #26
budgetlt1's Avatar
i think my problem is since my linelock isnt holding the car very long, my burnout is not long enough to heat up the tires. i'm gonna check for air on the lines, otherwise i'm not sure why the car wont stay still during burnout.
Old 05-28-2009, 08:44 PM
  #27
budgetlt1's Avatar
ok i re-bled the front brakes-no air came out. i did notice the pads are aftermarket and look like the last "brake job" was just a pad slap because the rotors have slight grooves and the pads look new. i will machine the rotors and replace the pads w/gm pads and see how it goes. today i out my new stall converter in so that should help my launch if i can hook good. i'm racing tomorrow so i'll post new times saturday.
Old 06-09-2009, 11:48 AM
  #28
pHEnomIC's Avatar
I ran 13.9@101 on my stock lt1 w/ 2.73s and a4.
pHEnomIC is offline
Old 06-10-2009, 11:22 PM
  #29
budgetlt1's Avatar
ok, got my burn out sorted out better, ran a 13.4 at 102. still cant launch aboce 1200rpms or so or else i spin. checked the video and both tires are definately spinning. i added roller rockers and new valve springs this week so we'll see what i can pull off on friday. hopefully i can hook well. thanks for the advise guys. i'll post new times soon.
Old 06-10-2009, 11:52 PM
  #30
Z-RATED94's Avatar
How old are these tires your using? There's no way you should be spinning off the line. What did you say your running the tire pressure at?
Z-RATED94 is offline
Quick Reply: quarter mile time for stock lt1
