Please help me fix my launching issues
#16
also i'm wondering what is the proper way to adjust the control arms, how will setting them in the lower or upper slot adjust the suspension/traction?
edit ***
ah, i definatly think these will help, the car is lowered and i just crawled back under the car and looked again and he definatly didnt use these brackets so the rear of the control arms do sit above the front, i dont think i can find em locally unfortunatly hopefully i can get em here asap for next weekend
edit ***
#18
yea, im definatly getting the brackets, im just trying to figure out whats the difference between the 2" drop and the 3" drop hole, looks like UMI has a whole ebay store which is cool, is there a reason you said you prefer the UMI over the edelbrock? Also im looking at the control arms and what would be the benifit of an adjustable arm over a non-adjustable?
also wanted to clarify on my burnouts, i should be doing just a quick one with the tires dry correct?
#19
I always start in the water and after the smoke is going roll out with the tires spinning. As far as the edelbrock ones they make good intakes and such but I have heard bad things about their torque arms. UMI just does suspension stuff. You get my point not that either bracket is that much better but if one company has been specializing in on style of product they might have more proven peices out there. The lower you bolt the LCA the more antisquat you get. My rearend is set up with 5 adjustment positions for the LCA's and next year I will be in the lower hole and my car is not lowered. I also have 4 holes in the front for the torque arm which will adjust just how hard the car will hit the tires.
#20
huh, okay i'll try out the UMI ones, it looks like they have just 2 adjusting holes, im guessing you are on a 4 link setup? I'll pick 'em up and hopefully they'll help out, the M/T website said the the burnout on these ET street radials should be done dry but i guess its worth trying wet, i'll also try what you said on the launching, hopefully I will get this all narrowed down. Thanks for your help, now if i can just figure out the knocking i'll be set, lol but thats another thread (in the computer tuning section if anyone wants to look, haha)
oh yea, what about the adjustable vs. non adjustable bars?
#21
No I'm still stock suspended.
The rearend may not be perfectly centered in the wheelwell. The adjustable ones let you center the rearend if needed. If you ever decide to try a 28" tire you will have to get the adjustable ones to center the rearend.
#24
what do you think about these SFC's
I like the fact that these are 100% bolt in, i wouldn't have to mod anything, i can weld them in, but i think since they are bolt in it will be easier if i decide to pull the motor through the bottom later
http://www.umiperformance.com/2004?category_id=129
or these are 1/2 the price and weld in only
http://www.umiperformance.com/2000?category_id=129
http://www.umiperformance.com/2001?category_id=129
#25
try doing a good burn out ,once, then stage and launch off idle with the shifter in D
after getting the brackets, start in the lower hole
try upping the air pressure to 24#or 22#, some times when you let too much air out the center of the rubber doesn't have contact pressure, and you will be spinning two little streaks
good luck
#26
there's your problem LOWERED
good luck
good luck
okay great thanks for the advice, how will i know if i need to move the bars up to the 1st hole as compared to the second (lowest) hole, I'll try bumping the psi back up and see what happens to the 60's and my launches. What do you think about the SFC's i posted? I'm gonna try picking up the brackets and the SFC's and hope they get here intime for next weekend
#27
I have Strange adjustable front coil-over shocks, no sway bar up front, adjustable Midwest Chassis torque arm(very adjustable), adjustable lower control arms, relocation brackets for the lower control arms. That is my adjustability parts, I also have a 12 bolt rear so that I can use slicks and launch @ 5500rpm. I also have a spec 4 clutch which can take some of the abuse I give it. That how the 12's are possible with a stock motor.
#28
i pulled the M/T's off today and threw my street tires back on, i took some pics of the M/T's, it looks like the rubber was balling up more on the outsides of the tire and not so much in the middle, is this normal wear, or does it look too much or too little pressure, like i did too much of a burnout? to little? should have done it in the water box? or is this normal?
#29
