Ok so who is going to win??
My buddy wants to race his 98 Formula LS-1 stock, automatic w/ 3.23 against my 97 z-28 LT-1 w/ k&n, 3" cat back flowmaster sys., tb bypass, manual 6 speed w/ 3.42.. Both have the same tires and size 245/50ZR16. Who do you put your money on? My guess is its going to come down to the driver. I think both cars are pretty even.
Just got my first Camaro, a 97 Z-28!!
If your only mods are a catback and K&N and tb bypass then I will give the race to the 98 Formula, even if you are an excellent driver with that 6 speed the LS1 just has a larger power advantage over you and in a quarter mile race will probably beat you by about .4 seconds which actually means you will probably be watching his tail lights from a few lengths back. It does depend somewhat on driving, if you are very good and your friend sucks then there is a chance but the fact is he has about 20 horses on you and will probably win, keep us posted after the race, I would like to see the outcome.
I dont think there is that much of a hp diferance. My z is rated at 285 stock, I would guess my mods would give me about 15-20 extra HP. Aren't the Formulas about 310 stock? That would put me only at about 5 hp less. Please correct me if Im wrong I'm still new to the scene. I do think he would win but I think it would be really close.
having owned both LS1's and LT1's I'm going to have to put my money on the LS1. The rating of the HP on the LS1's is an understatement. My 98SS when it was BONE STOCK and it only had 150 miles on it dynoed @ 300rwhp. In the last few years I believe the LS1's even have more power. Your LT1 would pull down about 260rwhp. So car to car he will probably beat you. It will just depend on your launch.
Also, just a side note for you,
My 98SS(M6 car) ran 12.97@109.75 w/ an air filter and underdrive pully.
My 99 Z28 (A4) ran a 13.6@104 w/ no mods at all.
My 98 C5 (A4) ran 13.1's@107 with Filter, 80mm throtle body, and HPP3.
My 97 Formula(M6) ran 13.7@102 w/ a borla and K&N Filter.
My 97 Z28(A4) ran 13.7's@101 w/ borla/K&N/HPP/shorty headers/3.42's.
All times were taken at the same track. Every one of my LS1 cars have been way faster than my mildly modified LT1s.
However, on the street it's a different ball game, if you are going from a roll he will crush you. But from a stop, if you can launch and he spins his tires you'll beat him. I've lost a lot of races due to lack of traction.
None the less.. Good luck!
Jason
Plates: "Stock 95"
1995 Firebird Formula
O'ring/4bolt 383, GTP Race Ported AFR 210s, Yank TH400, Yank 3800 Stall, Trans Break, Moser 12 Bolt w/ 3.73s, and the usual stuff like Hooker Long Tubes, Holley 58mm TB, Sphon Torque Arm, etc....
[This message has been edited by Wicked (edited July 19, 2002).]
Jason
Plates: "Stock 95"
Well, I looked at your orginal post again. I see he has an A4, I think the burden of traction is going to be on you with that stick.
Also depending on what speed you start out at on a roll, you may have a better chance. My 99Z if I remember correctly was violant fast at 60mph. My C5's speed was 40mph. With your stick, you may be best talking your friend into racing from a roll.
Jason
Plates: "Stock 95"
Jason
Plates: "Stock 95"
Actually, I hook up great! It churps a little but not much more, he has the problem with traction. I figure he will win but he isn't going to spank me like he does gt's. I'll let you know what happens, it probably wont be untill labor day holiday till I see him agian. He lives in Richmond, Im in Allentown, PA. I just got the car on 7/8/02, we stopped on 7/7 with him to look at it at the dealership (which was closed because it was Sunday) and thats all he has even seen it. Took it for a test dive the next day and I was hooked.
[This message has been edited by importeater (edited July 19, 2002).]
LS1 dong sucker alert here.
Remember, all LS1 run high 12's only with a Ford driver.
Next time I see an LS1 f-bod on the highway, I am just going to pull off the side of the road and hope he or she does not try to start anything because what can a lowly LT1 do?
1996 Z28 Camaro
2001 best 1/4 BFG DR's NA - 11.865@113.57 w/1.634 60', 1/8 - 7.563@89.82mph Best 1/4 MPH 114.82 - Best 1/8 MPH 90.73 - 2002 Mid 11's NA, Mid 10's n2o
1989 GMC 1500 truck for work 18.1@73 305
8 cats to feed clean after 1999 V6 Mustang 5 speed
15.358@89.47 MPH w/ 2.227 60'
15.364@90.92 MPH w/ 2.383 60'
1996 Z28 Camaro
<font face="Verdana, Arial" size="2">Originally posted by CANTONRACER:
</font>
</font>
Jason
Plates: "Stock 95"
RX Speed Works
09-11-2015 03:31 PM
88IROC_Z
07-22-2015 11:38 PM
