Not going back to the track without some Mickey Thompsons.
Old 06-26-2010, 09:14 AM
'94 Bad A Z28's Avatar
I can't stand Nittos, lol.
Only got like two descent 60's out of them.
1st pass:
60'........ 2.003
330'...... 5.466
1/8....... 8.221
MPH...... 89.84
1/4....... 12.548
MPH...... 112.78
2nd pass:
60'........ 2.010
330'...... 5.359
1/8....... 8.084
MPH...... 90.55
1/4....... 12.397
MPH...... 112.93
3rd pass:
60'........ 1.839
330'...... 5.143
1/8....... 7.855
MPH...... 90.87
1/4....... 12.515
MPH...... 113.26
4th pass:
60'........ 1.996
330'...... 5.341
1/8....... 8.067
MPH...... 89.09
1/4....... 12.358
MPH...... 113.16
5th pass:
60'........ 1.936
330'...... 5.265
1/8....... 7.980
MPH...... 92.51
1/4....... 12.267
MPH...... 115.33
6th pass:
60'........ 1.868
330'...... 5.166
1/8....... 7.872
MPH...... 92.71
1/4....... 12.154
MPH...... 115.42
Final pass:
60'........ 1.943
330'...... 5.269
1/8....... 7.987
MPH...... 92.75
1/4....... 12.269
MPH...... 115.36
Maybe I should just get some wheels other than my ZR1's to go to the track on. One day I'll do that, and get around to taking some weight out of this pig too.
'94 Bad A Z28 is offline
Old 06-26-2010, 10:50 AM
slowride94z's Avatar
yes sir that thing is strolling... look for some 11s with good tires
slowride94z is offline
Old 06-26-2010, 11:55 AM
Lat time out on M/T's it went 11.80 @ 117 on a 1.73 60'.
Old 06-27-2010, 09:50 PM
slomarao's Avatar
get some rubbers and get back into the 11's
slomarao is offline
Old 06-29-2010, 09:23 AM
Ricardo's Avatar
You will be back sooner than you think...........
Ricardo is offline
Old 06-29-2010, 10:25 AM
Super Moderator
JakeRobb's Avatar
My father in law was getting 1.7 60's on 555Rs on his 4000lb big-block Buick.
Not saying MTs aren't a better tire -- just that something about your setup isn't allowing you to take full advantage of what the Nittos can do.
JakeRobb is offline
Old 06-29-2010, 02:58 PM
I know Nitto's can do 1.7's, hell a friend of min got his to go a 1.4, all I am saying is that the are not as good on my car as a M/T for whatever reason.
Old 06-30-2010, 07:11 AM
Moderator
AL SS590 M6's Avatar
Apples and oranges Jake. Different car, different power band, different trans gear ratios, and totally different suspension system. You can NOT compare the 2 at all.
AL SS590 M6 is offline
Old 06-30-2010, 07:31 AM
Super Moderator
JakeRobb's Avatar
Sure I can.
A quote I've always liked: "Comparing apples and oranges is easy. Comparing apples to apples, on the other hand, is an exercise in futility."
As far as the tires are concerned, on two cars with solid rear axles (and assuming that both are properly centered), it seems to me that the primary relevant variables are track prep, tire size (my FIL is using 275/60/15s), tire pressure, and weight transfer. All of the things you listed are things that affect weight transfer.
The OP blames the Nittos for his bad short times. I agree completely that a set of Mickeys will cure the symptoms on his current setup, but IMO it's a band-aid for another undiagnosed problem (or possibly multiple problems) which will remain and which may come back again (possibly with different symptoms) if he continues to add horsepower. Then again, the additional horsepower or other powertrain modifications made to support it (different trans/gears/converter, etc) might solve the problem anyway.
If he doesn't care or doesn't intend to add much more horsepower, then everything I'm saying can be ignored -- but it's still true.
JakeRobb is offline
Old 06-30-2010, 04:53 PM
AutoRoc's Avatar
Get them smoking GOOD, 19-20psi... that was my best result..That's not bad at all! is this with nitrous? If so, you did really good. I had a HARD time going 12.99 on 315 Nitto's when I had a tiny motor and nitrous. The torque spike instantly breaks them loose. I'd spin and go 13.00X all day. ET Streets got me to 12.80.
Rod442 does well with his Nitto's, especially considering it's a 6 speed and has boost.
Last year I got 315 Nitto's to go 1.72, I'd call it luck though. It was 1 of MANY passes. The problem now is the 4500 stall.. rolling into the throttle slowly is a real patience test. Full throttle about 40 feet out and when it stayed hooked up I was actually cheering in my helmet. It hadn't done that all day!
AutoRoc is offline
Old 07-01-2010, 06:07 AM
Moderator
You totally missed the point of my post. The suspension of a Camaro, even though it has a straight axle, is totally different than an old Buick. It's shorter and tighter so it doesn't transfer weight anywhere as well in stock form. I know from personal experience what it took to make my Firebird hook well.
Yes everything you said was true. He could spend the time and money to make it hook on Nittos. Or he could do as most do and over tire it for cheap. Most don't want to spend the money or make the suspension compromises that a drag set up requires.
Old 07-01-2010, 06:13 AM
Moderator
But.....................there's always a but. Rod's car has aftermarket LCAs, LCA relocation brackets, QA1 12 WAY adjustable shocks all around with drag launch springs in the front, and a BMR torque arm.
I would dare to bet that without these suspension mods it would just be a smoke fest with the Nittos.
Old 07-01-2010, 06:31 PM
275/40/17's and no nitrous, N/A.
The car only has a little suspension work, and it has a key component working against it, the springs.
The car has:
UMI Weld In SFC's
BMR Tubular Adjustable T/A (set to -3*)
BMR Tubular Adjustable Pan Hard Rod.
SLP STB
SLP John Aims Lowering PKG... aka Eibach Sportlines
I know the springs are pretty much killing my launch, but they were the first thing I did to my car, ten years ago when I was in HS. I really do like the way the car sits a little too much to get something like a "drag" kit, but I do plan on at least swapping them out for some BMR lowering springs, my friends LS1 car went 1.5's all day with those and M/T's when it only dynoed 360rwhp.
Besides that, whenever I have the money I will get a bigger rear sway bar, LCA's and LCA relocation brackets at a minimum. Until I can do that I will have to just suffer with my crappy 60's, but it is what it is.
DirtyDaveW
12-01-2016 05:37 PM
10-31-2016 11:09 AM
Feffman
10-09-2015 05:42 AM
192cobra
01-26-2015 12:12 PM
Louey
Pacific
12-25-2014 03:27 AM
Quick Reply: Not going back to the track without some Mickey Thompsons.
