New Lt1 Stockhead best
#33
No fast caddy I don't want to confuse you. You said I wonder what Franks car would run with a 305 or 306 cam. And my reply is maybe Comp Cams will send me one for Christmas. If and when I change cams I'm sticking to stock heads. Now if any cam company would like to send me one to try i'm open Frank95z
#37
Frank how are you leaving the line in that? If I rember right you took out the A/C too right?
Sweet times I need to gut mine a little but I will not let the A/C go. 1 more question do you have a rollbar? If not your cheating
Sean
Sean
#38
Funina91ss I did remove ac but not heater or defroster. I leave the starting line 2 different ways. When I bracket race I stall up to 1500. That method gives me the best reaction times. To run fast i leave off of dead idle. The suspension seems to work better this way with no preload. I do have a rollbar,5 point harness,driveshaft loop,steel stems,firejacket and Snell 95 helmet. So I am legal Frank95z
#39
I had you mistaken for someone else sorry Nice weight in #'s with a Bar in it Your car must hold a few records mainly the 60ft for a stock heads and bottemend car with no poweradders. But that might have alot do with your cam being smaller it pulls harder down low I bet. either way You have a great combo that works. My hats off to you.
