Need help, hard launches are destroying my car.
My 94Z twist terriblly everytime I launch at the track. It twist so bad that it has broke the fiberglass shell on the driver side door. I have a welded in 8pt rollbar, SFC's, and a BMR trak-pak that uses a 1 5/8 steel bar to connect the sfc's together and the left tire still gets 12-18 inches up on every launch. The car has t-tops which I know is hurting me, but is there anything else I can do? Thanks.
Randy
94Z 355 cid Hughes performance TH350 with 4000 TC, ported and polished 2.00, 1.57 valve heads, ported intake, 52mm TB, Bullet custom grind cam, Comp cams R series lifters, Hooker LT's, custom dual exh. with dynomax bullet mufflers,CSI elec. WP,MSD Digital 6+ ign,Autogage 5" monster tach with shiftlite,AC delete pulley, CC pro mag 1.6 rockers, Forged Ross pistons, 11:1 cr,B&M Pro stick shifter, eagle rods, polished stock crank,balanced rotating assembly , 24lb SVO injectors,Nitrousworks wet kit, AFPR, pcmforless custom program, alston SFCs, boxed LCAs with relocation brackets, tubular panhard rod,chassis engineering 8-point rollbar with 5-point harness, BMR Trac Pak, moser 12 bolt with 4.10's,1LE DS,Hurst line lock, eibach drag launch kit and airbag, HAL 12 way adj struts,CE 3-way adj. shocks, 15x3.5 front and 15x8 rear Weld Draglites with 27x11.5x15 Hossier QTP's. 1.57 60ft 7.57 @ 90.62 mph 1/8 12.02 @ 112.48 mph on motor.
1.55 60ft 7.16 @ 96.04 mph 11.27 @ 118.41 mph (125 shot) Shooting for 10's
In memory of the greatest
#3 Dale Earnhardt The Intimidator
Randy
Sounds like you need a Wolf or BMR Rear Swaybar.My car was twisting pretty bad,but never hurt anything.
I have pulled 1.51 60's with the same thing,left front in the air,right front barely up.
I just did the BMR Extreme Duty swaybar,and it leveled the car out nicely.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Dirk
1997 TA A4
The RacinLT1
RacinLT1 pic's
I have been running 18 pounds in mine and it helped straighten out the car on the launch. Now I only 60' in the high 1.5's. but the drivers side tire gets a bit of air and the car goes straight. If I have less air pressure it wants to hook right.
'94 Black Z28, 383, 700R4
1/8 ET: 7.48
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
1/8 ET: 7.48
1/4 ET: 11.86
1/4 MPH: 112
mark0006
12-25-2014 09:50 PM
Hoodshaker
08-27-2002 02:32 PM
