Madmans got power
Madmans got power
Finally got the motor finished for our R&D car. Check it out at www.madmanandcoracing.com/madmanscamaroupdates.html
Insanity at its fastest
Worlds Fastest Blown 4th Gen
9.18@ 152
First 9 sec. PROCHARGED F-Body
In Memory of TONY OWEN driver HYDROMANIA
9.18@ 152
Looks good
I like the funny car cage.
Do you sell seat brackets that fit a 4th gen and are for the plastic seats. I need some bad.
96 T/A 6" rod 355 c.i
Stage 3 heads and cam
A4p.o.s soon to be A3
And a little N.O.S
Looking for 10's
And a little N.O.S
Looking for 10's
All the seats we install are the aluminum Jaz or Kirkey seats. I build brackets per application. Any chassis shop should be able to build you some.
9.18@ 152
9.18@ 152
Looks awsome man
I take it it's not your daily driver
seeya
John
John
My Blown396Z site
Silver 96 Z/28,6 spd.
Team NEDyno/Quest Racing supercharged 398 in progress
seeya
John
John
My Blown396Z site
The alt. bracket and motorplate were designed to work without A/C. I havent had anyone try to fit the a/c back on. The alt sits where the a/c is stock.
9.18@ 152
9.18@ 152
The block is a Dart Iron Eagle, the heads are Brodix. A LA Enterprises Billet crank, GRP aluminum rods and ROSS pistons.
9.18@ 152
9.18@ 152
Sounds like she is going to be a handfull
Nick D'Agostino
1997 Silver Camaro SS
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
4L60E Race Built Trans
TNT Twister NO2 System
Best Times To Date
NA Time 12.15@111mph
NO2 Time 10.66@128mph
E-Mail For More Info
1995 Emerald Green Formula
Stock For Now
Times to Come
If you live life by the book, all you get is what has already been written.
I am a Proud Supporter of ......Boycott Lapeer Dragway
Nick D'Agostino
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
Best Times To Date
Stock For Now
Times to Come
Hey good choice on the block!! You must have heard some of the same things about the Bowtie blocks I did. I went with the Little-M Dart block myself.
Good luck Brian. When do you expect to be kicking some 8 second ***?
-Curt Ailes
86 IROC w/ T88 Turbocharger
http://www.hustonstreetracing.com
-Curt Ailes
I hope to have it running this week. Everything is plumbede and wired. I have to put the interior back in and start making test runs. The car should run low 9s on motor and then the dope should a ride.
9.18@ 152
9.18@ 152
F'n1996Z28SS
08-23-2023 11:19 PM
NewsBot
05-16-2015 03:40 PM
