LT1/powerglide 4 1/8 racin'
#17
#18
That may be true, but that doesn't mean it can work for him. If he gets a good converter built for his particular application, and gear it properly a PG will be as deadly a bracket car as you'll want and it's easier to drive at the starting line and down track.
Randy
Randy
#19
#20
450whp,550whp,650whp
I do not have all parts for short block yet, so compression can be adjusted, pump gas not required, preferred only.
#21
you never hear real drag racers talking about rwhp.....
I would hold off on the glide until your launches get too violent...wheel stands, or blowing the tires off.
#22
We have a winner here. This application is to build a bracket car. Soft launch (some say turdish), bat out of hell on the top end, and able to predict ET's dead on. Most who post here don't bracket race and it is a much different approach than best ET bragging rights. Only have to do you best ET once, bracket racing you have to be dead on every run. Faster in bracket racing doesn't give a whole lot of advantages. Personally I perfer having the slower car and feel it give me the advantage. Running 12.0 at 118mph with a 1.70 60' ain't much for bragging rights but it sure gets a lot of win lights on Saturday. Same can be said for the stock Mustang running 14.0's at 97mph with 2.150 60' putting 9 and 10 second cars back into their trailers. This is all about setting a car up to bracket race.
#23
throw rwhp out the window that big *** converter is not going to make any rwhp, justy forget that. rwhp is for internet heros....
#24
#25
I bracket race
My car printed the exact same number 3 passes in a row last time with a 350 trans....
a glide is not much lighter than a 350.
I ran 5 4.25 in the 330 in a ROW...... your not going to get much more consistant than that
and I still got put on the trailer 2nd round, finish margain was .019
#26
My turbo 400 is very sentisive to shift points. Good point is if I stage a bit too deep I can raise my shift points a to get back the .02 or .03 I lost on the launch. Bad is if I miss the shift point by 100rmp I'll be off my dial. Have to make 2 perfect shifts. Glide there is only 1 shift and you can make the shift at a physical point on the track not by rmp. This will adjust staging mistakes. I race 1/4 mile which is much less forgiving that 1/8 racing. I was beaten with a .011 package then lost first round again the following week with a .007 package (that's .002 RT and running dead on with a .005). Driver of the winning truck (that's a 9 second truck) was .002 on the tree and dead on with a .002. Footbraking Taking a .010-.019 mov is stellar top end racing.
#28
I bracket race
I bet the winner had a 2spd. just playin!
#29
I bracket race
#30
you think this guy is going to be all that serious? I bet its his first car......
he won't have a PG 6 months, b/c all his buddies are going to outrun him.
turbo 350's are king of the world!!!
everyone has an opinion.....
