lt1 guys post ur 1/4 mile times and mods and A4 or M6
Re: lt1 guys post ur 1/4 mile times and mods and A4 or M6
I don,t feel like typing out everything on the car.
Here are the basics, LTs, true duals, CAI, Ed Wright tune, suspension stuff, stall, 3.73s.
13.4 at 104 with a best 60 foot of 1.89. This was done with a completely internally stock LT1 with just under 160K on the clock.
I have had the car on a diet recently and have the weight down to around 3150 without me in it.
Should run 12s if I can get it to hook up.
255lph FP,Headers,Ram Air,MagnaFlow,Yank 2800,Hotchkis Rear Susp and SLP DD Subs.3720lb race weight on 17's=13.417@101.35
No new times with Aluminum DS, tranny rebuild and Madwolf tune.
H/C swap this winter, 30lb injectors, CC503 cam and Electric WP,times to come
The fastest I went @ a track was 12.3 w/ just a Procharger, cat-back, some small suspension mods and slicks back in the day (2001??). Stock converter, manifolds and stick, no port work inside the motor. The ECM was tuned by me w/ LT1 Edit.
It went a little faster on the street though.
13.98 @ 9? mph 2.22 60' stock other than K+N in stock airbox
13.22 @ 10? mph 2.19 60' street tires, 306 cam, Pacesetter longtubes, K+N CAI, 1.6 RR, March underdrive, TB bypass, LT4 KM, Cutout after cats, MadZ28 tune, 3.73 gears, SFC's, LCA's
12.78 @ 109 mph 1.92 60' drag radials, same as above mods
3760 lbs race weight
13.6 not consistent on 18" wheels/tires with only moroso cai and cut out
13.5 consistent same wheels tires with ported tb and new intake elbow trick flow
Last year ran best of 14.3 at 96mph with a 2.18 60ft. I didn't run the vert this year but added 2800vig,30 svos,58bbk tb,asp underdrive balancer and pretty much all the supension stuff you see in sig...springs,kyb agx ,my spohn stuff,lca brackets. I had nittos on the car for the 2.18 run but wasn't really heating them up right and the track was a skating rink that day totally unprepped.
I think the car could hit a 13.8 or so pretty easily with current mods. Raceweight was a heavy 3850 and have added some heavier crome z06 mags and 17 inch rubber this year too.Altitude of track was 1700 feet.
I was planning on purchasing some kooks longtubes and LE2 heads hopefully by spring and then install them with my uninstalled CC305 and 1.6 Pro mags and my zex wet kit. Hoping to see mid 12s out of the heads/cam/headers and bolt ons and mid 11s on the spray.
Of course track will boot me for under 13.5 so may only get one good run when finished modding it up. May try one run in spring with just the mods in sig. And hope don't hit a 13.5 with them.
11.7 @ 117.5 short shifting becuase of miss.
m6 stock bottom end fms cam, chs heads... all bolt ons and true duals.
now if i could just get that miss fixed.
See sig...LPE 383 with small Joe Overton cam, 16x8s all around little 16" M/T DRs, both sway bars, and Spohn/Hotchkis suspension with stock springs/Decarbons...
--Alan
--Alan
