i need help with gears in my 81
3.73s will generally be stronger than 4.10s, and you will, need to recalibrate the speedo if you want to drive it on the street as the speedo is likely tied to your odometer as well.
Depending on your power level you may also want to incorporate wheels and tires into the final drive equation with taller tires resulting in slower 60 foot times but maybe a higher trap speed. Taller tires will also generally have more sidewall area which is a factor if you decide to use a tire that wrinkles at the launch.
What is the goal of changing your gear ratio?
ChrisFrez
03-22-2015 09:12 AM
