how much air psi w/mt et streets? 60ft?
Old 06-15-2009, 10:22 PM
budgetlt1's Avatar
just wondering what pressure other guys are running with mt et streets-mine are 26x10.50r16 also what are your 60ft times? thanks
budgetlt1 is offline
Old 06-16-2009, 06:37 AM
Moderator
AL SS590 M6's Avatar
ET streets 15-16
ET street radials 21-22
AL SS590 M6 is offline
Old 06-16-2009, 08:26 AM
northdakota93z28's Avatar
this was from mt tech.
On the road you will need around 32 psi at the strip run 12-16 psi.
northdakota93z28 is offline
Old 06-16-2009, 08:46 AM
cause4panic's Avatar
http://www.mickeythompsontires.com/tech.php?bulletin=s3
http://www.mickeythompsontires.com/tech.php?bulletin=s7
cause4panic is offline
Old 06-18-2009, 11:52 PM
Moderator
rskrause's Avatar
Mine worked best with ~12psi. 60' were in the low 1.5's.
Rich
rskrause is offline
Old 06-20-2009, 10:18 PM
Trickyrick33's Avatar
Run mine at 12 psi and am pulling 1.7's with an A4.
Trickyrick33 is offline
Old 06-21-2009, 10:09 PM
AutoRoc's Avatar
12.5psi hot and they went 1.55 motor, 1.45 hose.
AutoRoc is offline
Old 06-30-2009, 12:05 AM
ss#1230's Avatar
those two pages contradict each other. i ran mine at 16 (315 radials) and the didnt hook well at all, but they werent broken in yet, so that isnt a good indicator.
last time they stuck much better. i ran them at 18, then at 17. not much difference in 1 pound, but i wanted to keep the variables down and just work on my launch technique.
since that one bulletin says that the 295 and above radials should be ran at 11-14psi on 3000lb cars and above, i think next time i go out i may try and run those bitches at 12 and see what happens. i honestly dont see it being any better since the sidewall isnt really going to give regardless of the psi, and in getting a lot of contact patch at 17-18 psi...
oh yeah, best 60' to date is a 2.11. either bog a bit, or spin a bit.....
ss#1230 is offline
Old 06-30-2009, 12:18 PM
not they do not, et street <> et street radial
Old 06-30-2009, 01:03 PM
ss#1230's Avatar
what is the difference in the ET drag radial and the ET? ive never seen an MT ET Radial that isnt the "Street".
i was comparing the instructions for the ET radial on the first page vs. the ET "street" radial....
ss#1230 is offline
Old 06-30-2009, 01:06 PM
ss#1230's Avatar
well i just looked them up. ive never seen those before.
but does 11-14psi on my 315/35 17 street radials sound right?
i think thats way too low.....if anyone else has tried it, lemme know.
ss#1230 is offline
Old 06-30-2009, 01:14 PM
davidz28guy's Avatar
i dont know if my logic is correct but i always tried to run as much air as i could without spinning, i was cutting 1.6 60fts consistanly at 19-21 psi on my 315/335/17s et street radials, car was a a4
davidz28guy is offline
Old 06-30-2009, 03:21 PM
ss#1230's Avatar
that sounds right. my problem is that im an M6
here are some pics after running 17-18 psi.
i dont think anything less would help me any, because im getting a wide contact patch.
you can see where the contact is when im running 32psi on the street, and also where its contacting when im running 17-18psi....
ss#1230 is offline
Old 06-30-2009, 10:55 PM
CamaroSS30thAnn's Avatar
32psi is too much for the street. Youll wear out the centers quiicker
18 to 22 is a much better choice if you want them to last
CamaroSS30thAnn is offline
Old 06-30-2009, 11:42 PM
ss#1230's Avatar
the MT tech page says to run them at 75% of the max psi posted on the side wall....
max psi is 44. 75% of that is 33psi.....
i may drop them down to about 26-28 though. just enough to get more contact patch on the tread....
ss#1230 is offline
Quick Reply: how much air psi w/mt et streets? 60ft?
