What I can trap at the track with my mods?
Old 02-29-2012, 01:42 PM
2FASTBROZ28's Avatar
I haven't been able to go to the track to run my car due to this bipolor weather here in texas. I know to take off the front sway bar and tower to help out, but my main deal is seeing what I should be able to run?
Last edited by 2FASTBROZ28; 02-29-2012 at 01:44 PM. Reason: words didnt make sense
2FASTBROZ28 is offline
Old 03-01-2012, 11:52 AM
dennis5374's Avatar
Re: What I can trap at the track with my mods?
13's would be my guess. Street tires I'm guessing?
dennis5374 is offline
Old 03-01-2012, 12:09 PM
GRIDERMAN87's Avatar
On street tires it could be anywhere depending on how bad you spin, with a good run on street tires i would say low 14s--high 13s or so. With slicks you might get lower into the 13s
GRIDERMAN87 is offline
Old 03-02-2012, 12:27 PM
Yeah I'm just running street tires. I wanna get some dr for sure. Could I run slicks on a 10 bolt? I Don't wanna blow out the rear end just yet
Old 03-05-2012, 12:49 PM
Bersaglieri's Avatar
TRAP = MPH
ET = Time
Trap 103-105mph.
Slicks + 10 bolt = gamble. With a low stall you'd probably be fine, but those darn 10 bolts are hit or miss. I've seen guys run stock ones into the low 11's every weekend at the track. Then I blew one apart on the street.
I ran 13.6 @ 105mph one street tires a long time ago. That was at around 1500ft above sea level with just a few bolt on's and street tires.
-Dustin-
Bersaglieri is offline
Old 03-06-2012, 10:20 AM
whitdog54's Avatar
^yup, my buddy cut 1.6 60s on his 10 bolt dumping the clutch at 5k on ET streets. it whined a little, but lasted all season. he just sold it
id run a nitto 555R if you want traction in the rain and get 15-20k miles on them. ET streets if you want to consistently dead hook, only will get about 10k though beating the crap out of them. The nittos were the best tire ive owned, but im not making 450+hp
street tires? im gonna say 13.9@ 104
what gears? thats huge, im assuming 3.23s?
whitdog54 is offline
Old 03-07-2012, 03:14 PM
Yeah.
Thanks for everyone's impute!
Old 01-07-2013, 04:33 PM
bottle-fed93's Avatar
well since everyone is chatting about what they have and what times you all have ide like to see what yow think my 93 is going to run. its a 93 z28 with 97 lt1 with pcm for less tune, intake , ported intake manifold, londtubes with y pipe no converter, mildly modified trans very mild, and the stock rearend with 150 wet shot.
bottle-fed93 is offline
10-31-2016 11:09 AM
LETZRIDE
Outside of United States
07-09-2015 07:17 AM
weigh2fast4u
06-28-2015 08:28 PM
Flint78
06-21-2015 01:28 PM
R@mpage
04-20-2015 10:02 AM
Quick Reply: What I can trap at the track with my mods?
