E.T. Streets can i go 11.5"??
I wanted to post here because i figured those that read this forum would have the best idea--if i should or should not do this.
Alright here is the question......do you think i would be okay running the MT E.T. Streets 26.00x11.5X16 on the stock 8.5 inch rim?? here is the link
http://store.summitracing.com/defaul...=egnsearch.asp
The minimum recomended wheel width is 8.7" and the stock rim is 8.5". So it's .2" off from the minimum. The reason i was wonder is there is a 1.3 tread width difference between the 10.5 and the 11.5. Does anyone know someone running these on stock rims? I also plan on using tubes with these--if that makes a difference on if it's safe or not.....without them I am sure it would not be safe.
Re: E.T. Streets can i go 11.5"??
I bought 10" rims when I switched to that size tire. I know people who have run those tires on stock rims and not had a problem, but if I am going over a hundred miles per hour I want to be well within manufacturers tolerance for safety. It isn't worth the risk to do things the wrong way in my opinion. Also, they will hook better on a properly matched rim size.
Yea i'm kindof leaning to the 10.5, but i figured since it is only .2 off--that there recomendations are just ballpark anyway. +1 and-1 of the tread width, which they don't even consider sidewall height so. But the 10.5 is less weight and would hook it up just as well.
