New track times with a th350
Old 05-05-2012, 08:10 PM
mightymouse383's Avatar
Well after selling my t56 and buying a used th350 and then rebuilding it, I ran a 12.20 @ 114 mph with a 1.89 sixty on DR's.
My best pass with the t56 was 12.60 @ 113 mph with a 1.98 sixty. I will get slicks next and try for a better sixty!
mightymouse383 is offline
Old 05-07-2012, 12:25 PM
Mystery Bird's Avatar
Re: New track times with a th350
Always nice to improve and go faster, congrats. Do you have a higher stall converter in the TH350?
Mystery Bird is offline
Old 05-07-2012, 03:57 PM
Yes I have a higher stall, Its a Art Carr 3800. I hope to soon go a little faster, the tune is a little rich with AFR's at 11.9 at WOT, I am going to lean it out and see if I can get a 1.6xx sixty and hope to run 11.80's to 11.90's @ the 115 to 116 mph range......Let me know if that it wishing for too much, lol
Old 05-08-2012, 07:14 AM
If you can get that 60 down to a 1.6 that should definately be in the 11's. Good luck.
Old 05-08-2012, 05:38 PM
Hey Mystery Bird, can I ask what mods u have? engine size, heads ect.....Just trying to see where I stand aginst other cars...thanks
Old 05-08-2012, 05:55 PM
Old setup is in signature, stock internal LT1, home ported heads, XFI 280 cam, Edge 3600 stall, 3.73 gears, LCA's, SFC, and all the bolt-ons.
Old 05-11-2012, 03:12 PM
Headed to the track tonight, hope for a better 60', will post slip later.
Old 05-12-2012, 07:33 AM
Best pass I could manage was a 12.4 @ 115 with a 2.1 60'.....well at least I cut a .003 light...lol
Old 05-13-2012, 05:58 PM
96LT1TX's Avatar
I had to get some hoosiers to get any decent 60's but I think we are pretty close on the ET. Without the nitrous im at 12.1@115 with a 1.72 60'. Pretty sure there would be 11s without the nitrous but I cant get any better than 1.68 or so without the nitrous. I always see others at the track running 11.8s@115-116 but I just couldnt get it right.
96LT1TX is offline
Old 05-20-2012, 10:54 PM
LT10s's Avatar
Hey man glad to see you made an improvement. I am just about finishing up my swap from the t56 to th350 with about the same size stall. The car went around 11.6s @ around 118 and hoping to improve. Much like you the real reason for doing it is to make the car consistent. I did have one question what did you do about the vehicle speed sensor? This is where I am having some difficulty because my car set the VSS code and will not idle and I need to figure out what I am going to do about this. Any help in this area will greatly appreciated.
LT10s is offline
Old 05-24-2012, 07:48 PM
OK, I did a little trick. I deleted my ABS about a year agao when I still had the T56, when I installed the th350 I ran the vss harness and spliced it in to the front right abs wheel sensor. I then used tunercat to program the speedo until it was accurate. Really easy and pretty much free.
Old 05-24-2012, 07:53 PM
You might need to idle the car up a little seeing how it is a auto now. Also u need to stay with the t56 tune, if not u will have a ton of codes for the 4l60e.
If you have any more questions let me know, also the car is way faster with the th350. I ran a 12.1 @ 113.60 mph with a 1.76 sixty on a 28 inch drag click in 95 degree weather. I think with some good air the car will run a 11.90 or a 11.80
Old 01-15-2013, 08:22 PM
T/A lt1's Avatar
You guys need to work on the 60's and tuning. My old 355 with Le1 cam/le ported heads ran 11.60@116mph with factory 3.42's in the 10bolt. I ended switching to a Cc306 and got it down to 11.24@120mph with tuning and suspension on motor with only 355ci.
T/A lt1 is offline
Old 03-30-2013, 07:33 PM
Best new pass on N20 150 shot 10.800 @ 126.57 mph with a 1.52 60'
Old 03-31-2013, 12:04 AM
T/A lt1's Avatar
Nice, should only get quicker from here on. I have a great Vigilante converter for Th350/th400, sent it in when I pulled my engine out to get freshened up. I have since decided to go turbo LS and I have to start over with stall converter and I'm looking to make somebody a good deal on this Precision Industries converter. My 383 ran 10.80's on motor and on 100 n20 went 9,91@137mph. Lmk
T/A lt1 is offline
Quick Reply: New track times with a th350
