Bolt-On LT1 guys... who's shooting for the record???
Old 03-08-2005, 11:51 PM
SAR2K's Avatar
Lightbulb Bolt-On LT1 guys... who's shooting for the record???
Ok, I've been talking with quite a few Bolt-On LT1 folks here shooting for the 11's for quite some time now... Tekprodave and a few others who are busting their a$$es to get the #'s. Hats off to these folks!!! Hitting the LOW 12's & HIGH 11's with a bolt-on LT1 is no easy task by any means. You will not luck into those times. It's all about time & patience... BIG TIME! Those of you going for it PLEASE don't give up!!! I'm telling you a high 11.7 with a Bolt-On LT1 IS possible!!! I know what I ran inside & out and know what the car had left in it before I got kicked out for no cage... 11.7 CAN be done by a Bolt-On LT1 DONE RIGHT!!! Keep going after it folks!!!
For those who say it can't be done... whatever... sucks to be you.
to the Bolt-On LT1 people!!!
Steve...
SAR2K is offline
Old 03-08-2005, 11:53 PM
White_96_SS's Avatar
Re: Bolt-On LT1 guys... who's shooting for the record???
props to you my friend..
White_96_SS is offline
Old 03-09-2005, 12:23 PM
jaredwayt's Avatar
sar2k, can you perhaps let me know the simple thigns you did to run that?my car is in the works to be a bolt on lt1, and im shooting to beat your time! if im not mistaken you have an a4 correct?didnt you run with the belt off?and are you running 1.6 or 1.7 rockers?thanks for the help.was also wondering on your suspension setup.as a matter a fact just tell me everything you did to your car LOL!
jaredwayt is offline
Old 03-09-2005, 09:16 PM
97Z-M6's Avatar
who has the fastest stock bottomend lt1 with ported stock heads, and cam. and of course boltons. the reason i ask is that joe overton is designing my cam this week, and he has a lt1 full weight TA ported stock heads and his cam. and it hit 11.05 stock bottomend
sark the 11.26 you ran is with cam and ported heads right.
97Z-M6 is offline
Old 03-10-2005, 10:06 AM
roadtrip120's Avatar
I'm going for the bolt-on record
I put down 327rwhp and 349rwtq yesterday at Texas Speed
Last time at the track i went 12.9 @ 107mph 1.86 60ft
(In Amarillo Tx, DA 4200ft, ALT 3600ft)
I will be adding BMR sys parts soon, with that and some pro stars i should make a good run at the 12.34 M6 Bolt-on Record(at a better track , Dallas)
My camaro weighs 3400lb (with drive) What are you weighing in at???
Good luck with the quest
Who put down the 11.7 out of a LT1???
roadtrip120 is offline
Old 03-10-2005, 09:25 PM
Shon Herron's Avatar
As soon as I can aquire another DD that will haul the 2 kids and wife I will pullling the stock 97 in and going all out for the Bolt on LT1 record. It is going to be a long trip but it can happen. In all honesty I dont see it happening with Herron Performance in 2005. But I am getting parts stored up just waiting on the day I can pull it in and put it on stands!
Shon Herron is offline
Old 03-11-2005, 08:03 AM
Ken95Z28's Avatar
Shon, at least you got your priorities in order, Family first.
I'm pretty sure that SAR2K put the 11.7 down.
Ken95Z28 is offline
Old 03-11-2005, 08:19 AM
It's tough, but the best for all....great weather will come and go before I get to run hard.
And I know I heard about a 11.9 BO LT1 set up but did not know it was 11.7...I am going to try...all else fails (ie the motor blows up) I will replace it with a God touched LSx motor and pick up a second.....
Old 03-11-2005, 02:45 PM
jaredwayt's Avatar
nooooo, why ruin a perfectly good car, and put a LS in it?
Old 03-11-2005, 02:58 PM
When you want to run for ET only and do it bolt on you have to get a lighter motor and one that makes a significant more power stock than the LT1....
Really though, not sure what the future holds, i may carry on the LTx banner instead of swapping but you never know....
Old 03-11-2005, 05:45 PM
If I am not mistaken, LS1's weight 100lb HEAVER, not lighter
Plus there is a faster LS1 bolt-on record than the LT1 11.9
Old 03-11-2005, 06:41 PM
ScreamnChicken's Avatar
I will be going for the stock head, stock bottom end, stock rear end record this spring. I believe it is 11.86 or so.
ScreamnChicken is offline
Old 03-13-2005, 03:44 AM
SAR2K's Avatar
Nobody has hit 11.7's as of yet with a bolt-on LT1. The number to beat is 11.94 which was done 2 years ago.
Steve...
SAR2K is offline
Old 03-13-2005, 08:13 AM
Steve...
EASY!
Old 03-13-2005, 10:10 AM
Not that easy, SAR2K has held the record for 2yrs
Let me find an auto , otherwise it will just be the
M6 record of 12.34, Im not sure if i can touch that 11.9
Quick Reply: Bolt-On LT1 guys... who's shooting for the record???
