any perdictions.
any perdictions.
i have a 95 ta. with weight reductions. don't know the weight. cc306 cam 4000 pt stall 3:90 gear. prostar rims with mickey slicks.. and a 175 shot.. hoping to get into the 10:99 but i dont think i will get there.
I vote the LT1 will let go long before your car achieves your goal. And I am willing to bet this will end up hitting the lounge.
well I didn't see you state any head work... so if you're running a CC306 cam without a single bit of head work then you're going to choke that cam out.... so I don't see you hitting 10's on that setup unless you just left out some details... you'll also want to get yourself a set of QA1's in the rear to help those slicks because you're going to need one hell of a 60ft time
My buddy ran an 11.13 @ 125.xx on a heads/cam/150-shot setup on the LT1. Car went 12.teens on motor. 3600 stall, built auto, etc. You'll have problems hooking up if you hit it off the line, but that's the only way to get there into the 10s.
Moving.....
Mike
Moving.....
Mike
