60'
#16
My best 1/8 mile pass is an 8.12 @ 83 on a 1.700 60' time. I didn't have a helmet so I wasn't able to make any full passes that night. My best ever 1/4 mile time was a 13.53 @ 61 mph..LOL. That was from rolling out of it at the 1/8 mile and coasting through the 1/4. I'm hoping for mid twelves next time out.
#17
I've made numerous 1.6xx 60' times on the stock 10 bolt 3.73 gears/girdle/eaton posi with a 3000 stall on M/T DR and salad shooters. The last time I ran before I sold the ten bolt was a 1.589. It still held up fine on the drive home. I upgraded to the 12 bolt before I blew the 10 bolt and sold it relatively cheap for what I had into it.
#21
elevation has so much to do with times not 60foot so much but at 4000 feet i ran a 9.8 all motor with no mods and the same thing at 2000 feet ran 9.4 both 2.3 60' doing some bench racing i hope i can pull 1.7 60s and run a 8.7 all motor!! i hope
#26
Track time
Since your probably very close to Minot you need to make some runs there and find out for sure b/c the track does separate the b from the s (lol) and the alt. there is under 2,000 ft. Also my buddy has a 96z vert and even w/3.42,2800 vig stall,nittos, and some susp.mods can only do a 2.03 60ft.at our local track so any camaro that does a 1.8/1.7 60 ft. esp.w/stk susp.has to have lots of mods!The alt.at our track is 1600 ft. and my car w/less gear,no stall,less weight,than buddies couldn,t do under 2.0,and b/f i bought my mt et streets the mt tire rep.said i might do 1.95,so either there,s something screwy w/my car or just maybe it,s a lot harder to run these no,s than it looks.
#29
I hit a 1.84 sixty foot in my T/A at least 50 times last season launch on a 65 shot without anything more than a WOT switch.
Everything else on the car was stock besides bfgs, i didnt even have any of the exhaust done much less any aftermarket suspension. You should be fine as far as the 1.7-1.8 sixty time.
But with your mods i would imagine more of a 1.6 sixty AT LEAST if the track and altitude is good. If not i would go elsewhere to run my times.
