10.60 @ 131.97
Old 07-04-2010, 06:27 AM
jonesy's Avatar
10.60 @ 131.97
still can't get the car to hook. 1.56 - 60' ,everyone @ Martin friday night was complaining about track and water box being dirty, I tried about everything , loosened up rear shocks- from 8 to 2, ran front on full loose, tire from 12 to 10( M/T 28"-12.50-15) still had a hard time hooking. I don't race a whole lot but is that something to just deal with when tracks are like that or am I just missing something. I even dropped my launch rpm from 5,500 down to 4000
jonesy is offline
Old 07-04-2010, 09:46 AM
bkpliskin's Avatar
update that sig, that's quite the mph improvement. what have you done since your last PB
bkpliskin is offline
Old 07-04-2010, 10:01 AM
jonesy's Avatar
installed twin disc and changed from Nitrous works plate and solenoids to Nitrous outlet plate and solenoids and spraying 200 rather than 150. On Nitrous Works kit would make much difference from 125 to 175 jets.car ran best on 150 jets, on new kit can tell big difference, soon as I get it to hook up, then come the 250 etcccccc,.......... lol
jonesy is offline
Old 07-04-2010, 11:39 PM
1BADAIR's Avatar
what TA
and launch vids?
et streets?
stiff wall et drags work better with a manual
1BADAIR is offline
Old 07-05-2010, 06:26 AM
jonesy's Avatar
ET Streets, stiff sidewall, UMI torque arm, -3 degrees,Wolff drag swaybar,try to get a vid up later, have dial up here, stop @ friends and upload a vid, front tires lift about 8 " equally, but come right back down, doesn't carry it , 3500 race weight
jonesy is offline
Old 07-06-2010, 07:41 AM
Moderator
AL SS590 M6's Avatar
I had to stiffen the rear shocks and soften the fronts. With it set the opposite it would hook for about 10' then spin. Now it just hooks but mine is a footbraked auto so it's more forgiving than your stick. I run with the fronts on the bottom setting and the rears on 6 left and 7 right with an airbag in the right spring.
AL SS590 M6 is offline
Old 07-16-2010, 01:30 PM
TAGOES11S's Avatar
Hey Al,
I'll have to grab Jonesy and we'll meet you up to Martin or Stanton later in the year!
Dan Baber
99 Raptor
TAGOES11S is offline
Old 07-16-2010, 02:09 PM
Super Moderator
JakeRobb's Avatar
If everyone was saying that traction sucks, I wouldn't use that evening's performance as a reason to make any changes.
JakeRobb is offline
Old 07-17-2010, 06:03 AM
Moderator
Originally Posted by TAGOES11S
Hey Al,
Dan Baber
99 Raptor
That sounds like fun. Been a coon's age since we've gotten together.
Old 07-17-2010, 02:54 PM
crushah's Avatar
I've heard many say to stay out of the water box unless you're running straight slicks. Any grooves will hold water/moisture regardless.
crushah is offline
Old 07-20-2010, 09:57 PM
FryedClutch's Avatar
Whats up tim hey man ive been doin a little here and there and finally got my car to kinda work you should gimme a call sometime and we can talk about what your cars doin..
See ya
Sean
FryedClutch is offline
Old 08-24-2010, 03:32 PM
sc68z28's Avatar
132 mph should yield a 10.0 et, but you probably knew that.
I've been where you're at.
Got 2 words for ya, ADJUSTABLE CLUTCH.
Good info on adjustable clutches here.... http://www.chevelles.com/forums/showthread.php?t=232952
Also here, in the clutch tech section of the forums.... http://www.umtrnorth.com/
---Bill.
sc68z28 is offline
jonesy
01-15-2013 07:58 PM
jonesy
05-08-2011 04:04 PM
jonesy
07-15-2010 12:28 PM
Bret Kepner
West North Central
04-18-2007 09:59 AM
Quick Reply: 10.60 @ 131.97
