1 5/8 or 1 3/4
1 5/8 or 1 3/4
I am just doing bolt ons right now to my 93 trans am. I was wondering what size headers to get. Right now I was kinda just wanting to go for shorty headers, but later I wanna do some decent engine work. I was wondering if I would probably need to change to 1 3/4. The only shortys that I have seen that are 1 3/4 are MAC i think and SLP. I think hooker shortys are just 1 5/8. Thanks for the advice guys.
Unless it's a strip only car or you plan on adding a supercharger, 1 5/8" is all you need.
1 3/4" is large for a SBC. To get the most benefit from them you need to be making over 500 HP or shifting around 7000 rpm.
1 5/8" are good enough for up to a 406. For a 305, 1 5/8" are huge. Anything bigger than a 406 (434) should have 1 3/4".
If you plan on doing more than just bolt ons within roughly a 2-3 year time frame I would go with the 1 3/4 and have them coated. If not, save the effort and money and get some shorties.
I had Edelbrock 1 5/8 for two years and after I blew a wrist pin and put in a new shortblock I needed to go to a bigger size. The Edelbrocks worked fine for me with just a bolt on configuration but I did not have them coated so they were really ugly.
Whatever you get, if you want to keep them a long time, get them coated.
When determining what size headers to get, you have to decide where yo want your torque peak to be. Here's what to do:
Multiply your peak torque RPM by the volume of ONE cylinder
Divide that by 277088.5
Take the square root
Add 0.040 (for tubing thickness)
Multiply by 2
...and voila! You have the diameter that you need. Now get the closest diameter to that, and you're good to go!
Multiply by 2
The actual formula is pipe area = rpm × cyl vol ÷ 88,200. I don't know where the 88,200 comes from, though. When you convert area to radius, you have to divide the area by pi and then take the square root. (88,200 × pi = 277088.5 approximately) The rest is just adding the tubing thickness and multiplying by 2 to get the diameter. Hope this helps.
techstar
08-06-2015 11:20 AM
08-05-2015 08:35 AM
