WOT AFR of 8.5 Question
Old 03-10-2013, 05:34 PM
tieman327's Avatar
95 LT1 using lT1 Edit to adjust the tune.
normal acceleration AFR is 11.7 and once I go WOT the AFR drops to mid 8's to low 9's N/A . I am just looking for a suggestion on where the tune should be adjusted and approximately how much.
tieman327 is offline
Old 03-11-2013, 06:56 PM
Kevin Blown 95 TA's Avatar
Re: WOT AFR of 8.5 Question
Looks like your car is stock, why not put the stock tune back into it and see if that fixes it? If it doesn't, something is really wrong with o2 sensors, injectors, vacuum leaks, or exhaust leaks assuming it is firing on all 8.
But to answer your question, the two fuel enrichment tables for temp and rpm are usually used to adjust the WOT fueling (assuming a bunch of other stuff isn't all screwed up) and no one's going to be able to tell you how to adjust that out, especially if the engine isn't healthy.
Kevin Blown 95 TA is offline
Old 03-13-2013, 01:18 PM
bobdec's Avatar
Sounds like your AFR gauge is reading 3 low. s/b up around 14.7 driving and drop to about 12 at WOT.
bobdec is offline
95chwagon
05-27-2015 09:53 AM
Z28-50
Parts Wanted
02-21-2015 09:00 PM
pimpss96
02-12-2015 01:28 PM
MadMav
02-06-2015 11:02 PM
95chwagon
01-13-2015 09:19 PM
Quick Reply: WOT AFR of 8.5 Question
