VATS bypass. 3 or 3 thousand Ohms?
Old 08-29-2016, 10:52 AM
Rod Bender's Avatar
I am ready to do the VATs bypass and my key tests 3.00 with my meter set on the setting (a dot) between 200k and 20k. Do I need resisters to equal 3 Ohms? When I went to Radio Shack to buy my resisters all they had were resistors in the K values, i.e. 300k. Big difference!.
Rod Bender is offline
Old 08-29-2016, 11:13 AM
Re: VATS bypass. 3 or 3 thousand Ohms?
Not gonna be 3 ohms, since the pellet values are between 386 and 12292. You were probably on a kohms settings so it would likely be 3000 ohms. Buy a resistor or combination of them that equals anywhere between 2890-3150 ohms. Measure with a meter after you chain them together and before you use them to be sure they are in the range. Common resistors have about a 10% tolerance value to what they are marked as.
shoebox is offline
Old 08-29-2016, 05:24 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
These should do the trick: https://www.radioshack.com/products/...ant=5717277381
Use 3 of them in series.
Or these: https://www.radioshack.com/collectio...ant=5717280837
Use 2 in series.
GaryDoug is offline
Old 08-30-2016, 01:04 PM
Rod Bender's Avatar
Thanks, shoebox and Gary. I really appreciate the help.
Old 10-01-2016, 06:55 PM
Rod Bender's Avatar
I am back on the project. However, when I wire the resistors in series I get a reading of 29.9. But with the meter in the same setting the resistance through the key is 2.99. So what's with that?
Old 10-01-2016, 08:31 PM
Prominent Member
GaryDoug's Avatar
I suspect you bought the wrong resistors. They should have been 3 of the 1.0 kOhm or two of the 1.5 kOhm. I think you have 3 of the 10 kOhm or 2 of the 15 kOhm
GaryDoug is offline
Old 10-08-2016, 11:55 AM
Rod Bender's Avatar
You are right. There is no decimal point between the 1 and 5 in the package I bought. Duh!
DSMKilla
08-29-2016 07:58 PM
JTheJackal
08-26-2016 09:24 PM
Ronney13
08-13-2016 09:42 AM
5.7ftdeep
07-10-2016 12:37 PM
force10
07-07-2016 08:10 AM
Quick Reply: VATS bypass. 3 or 3 thousand Ohms?
