Tunercat/Datamaster question
I don't get on here much anymore, so if the question is one that has been hashed over a thousand times, please don't yell to loud at me lol
Has any one run those two programs on a Windows 7 machine? Also wondering if the driver for the USB box from Andrew works with Win7.
thanks
Skip
thanks
Skip
Re: Tunercat/Datamaster question
MichiganSkip:
I run TunerCATS (v 2.25) on an ACER Extensa lap top under Win7 (32bit) and have had no problems. BUT when I run Freescan it sometimes stops logging fresh data (about 20% of the time) which makes me worry everytime I use TunerCATS. I haven't been able to fix it so I haven't wanted to spend another $100 or so on Datamaster. I'd like to use Datamaster because having an M6, I think my PCM has inputs for A4 sensors that I could use to log fuel pressure, oil pressure and capture a 2bar MAP sensor output.
I run TC and DataMaster on a Vista machine with no problems, but was thinking of upgrading to a new laptop. Just wondering if those two will work with Win7.
Thanks for the response..
MichiganSkip:
The ACER originally had Vista os and WinCATS ran with no problems on that but ~50% of the time Freescan would log "stale" data. When I changed the os to Win7 (32) the logging improved to ~80% successful. If your programs work under Vista the conventional wisdom is they will work under Win7. BTW, I'm using Win7 (32) home premium.
Windows 7 Professional here.
I installed Tunercat and Datamaster exactly per instructions on the website and log/flash/read with no problems.
Setting the .EXE files to "compatability mode"(right click, select mode) before doing the install is essential.
I installed the same .EXE files on my home PC with Windows XP Pro without doing anything special and use that to read data, modify tables as well.
this is alot more practical use for an actual mechanic that works at a shop other than a dyi guy at home though so please dont flame me
I have run Datamaster to log 3 or 4 15-30 minute drives on my 94 (ODB1) Camaro. I am using an Asus laptop running windows 7 Pro 64 bit. I have the sampling rate set at the highest setting and have had no issues at all. It's a pretty fast laptop though (G73JH).
dluna333
15
03-13-2015 12:30 PM
jasonduaine
03-07-2015 09:44 AM
Hurin
12-13-2014 07:38 PM
