Scan9495: Free OBD1 scan app for 93/94/95 LT1
Old 12-06-2013, 11:40 AM
  #61
Rocko350's Avatar
re: Scan9495: Free OBD1 scan app for 93/94/95 LT1
I can confirm on windows 7 that this works on a b body for engine and transmission data. I like it. Great for someone who needs the tool. Cannot get ABS or SIR right now. What would you need to add those two modules for B/D bodies?
I may have missed it, is there a donation link?
Chris
Rocko350 is offline
Old 12-06-2013, 12:26 PM
  #62
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Chris
Thanks for the feedback Chris!
Realistically, I would need a module for each type to support. I have the data required to write the code without one, but I make so many mistakes that it would be irresponsible to release anything without a rigorous qualification/verification process. I want to minimize the possibility of giving bad data, which could cause a huge waste of somebody's time and effort.
No donation link. Don't really need the money; just doing it for the fame and glory ;-)
GaryDoug is offline
Old 12-11-2013, 05:24 PM
  #63
Stephen68's Avatar
Im just curious guys, is this software a code scanner only or can it be used for any tuning or adjustments?
Stephen68 is offline
Old 12-11-2013, 06:06 PM
  #64
Prominent Member
GaryDoug's Avatar
No programming or tuning. But it is more than just a code reader.
GaryDoug is offline
Old 12-15-2013, 02:18 PM
  #65
Rocko350's Avatar
Completely understand. If you are willing, i can round up the needed modules and send them to you. I know the Roadmaster and Fleetwood use a 4 channel ABS/TC. It might take me longer to get those. LMK either way.
Chris
Rocko350 is offline
Old 12-15-2013, 08:42 PM
  #66
Prominent Member
GaryDoug's Avatar
Chris
I'm going to pass on that for now. Just a little too burned out on this one after many months of work. I never really wanted to get into other years or models. That's what the free TunerProRT is for. You may want to ask around some of the forums where that is discussed to see if anyone has created a definition file for those modules. I know that some ABS and SIR modules have been done already.
Here is a possibility: GearHead EFI
And you could check the Tunerpro web site forums also. TunerPro User Forum :: Index
GaryDoug is offline
Old 01-19-2014, 09:29 AM
  #67
Stephen68's Avatar
Does anyone have a pin-out diagram for the OBD2 end of the plug? The plug end i purchased just has terminals in which to solder the colored wires to and not actual color coded wires. Thanks!
Old 01-19-2014, 09:42 AM
  #68
Prominent Member
GaryDoug's Avatar
Here is a photo. Ignore the wire colors in the photo. The black wire goes to pins 4 and 5. This photo shows black and red wires. The green and white wires go to pin 9 (this photo shows yellow). Solder directly to the pins (9) or to the holes (4,5)
GaryDoug is offline
Old 01-19-2014, 10:04 AM
  #69
Stephen68's Avatar
Thanks Gary, as far as the other color wires on my USB cord, are they used or not? Also, when u say the black wire goes to pins 4 and 5, im not sure how to do that lol....thanks for the help.
Old 01-19-2014, 12:15 PM
  #70
Prominent Member
GaryDoug's Avatar
The red , blue, and yellow are not used. Try to trim them so that they are not touching each other.
Here is exactly what you can do in the photo below. I finally found it in an old post
If you look closely at the little circuit board, you can see the silver colored tracks going from pin 5 to pin 4 and then to a couple of holes in the center. It is your choice to use either one of the holes (as shown) for the black wire, or to solder to the pin (4 or 5) like is shown for the other (green and white) wires connected to pin 9.
GaryDoug is offline
Old 01-19-2014, 01:43 PM
  #71
Stephen68's Avatar
Thank you very much good Sir, that is just what i needed to know......
Old 01-27-2014, 03:08 PM
  #72
Stephen68's Avatar
Can anyone please tell me how to post my data log from today?....
Old 01-27-2014, 03:12 PM
  #73
Stephen68's Avatar
never mind....i got it....could someone please take a look at my file and tell me what they think? well, maybe not....seems i cant post attachments now???????
Old 01-27-2014, 04:33 PM
  #74
You can't post attachments on this site. You have to upload the file to an FTP site, and post the url for it.
Injuneer is offline
Old 02-02-2014, 11:44 PM
  #75
Stephen68's Avatar
This may sound retarded but will this software work on a 97 lt1 or is it just 94/95?
Quick Reply: Scan9495: Free OBD1 scan app for 93/94/95 LT1
