P0107 & C0240 codes won't clear
OK, here's a weird one for you. I have a 2002 Z28 with 140k+ miles and original everything. It needed new cats cause it was throwing the codes for them. I figured while I was at it, I put in a new clutch.
Getting the old CATS off was a nightmare and I was sure I'd rip the bolts off the exhaust manifold in the process, so I decided to unbolt the exhaust manifolds from the heads and take out the CATS that way. This allowed me to use a torch on the rusted bolts and remove the CATS without destroying the manifold bolts.
The passenger side manifold came off with no issues, other than it was a bitch trying to get my hands in there to unbolt it. The driver side was another story. The first bolt (front of engine) snapped off the head and left about half an inch sticking out that I could grab and unscrew. I wasn't so lucky with the last bolt closest to the firewall. It snapped off flush with the head. So, now I had to take the head off to drill out the bolt hole and re-tap it with a heli-coil. Of course this meant taking off the manifold and everything else that goes with it.
Okay, so here comes the problem. I get everything back together again and all works fine, engine starts right up, clutch works great. No indication of rough idle or vacuum leak of any kind, except now out of nowhere I get a P0107 code (MAP sensor) and a C0240 code saying that the ABS is inoperative. BTW, the check engine light is operative, but it's not on. I only know there is an issue because my scanner says so. A coupe of times I was able to clear the codes for about a minute or two, then they came back. I checked the voltage for 5VDC on the MAP sensor connector and it's fine. I replaced the MAP sensor, still the code won't clear.
Just so you know, I disconnected the battery before I started and it stayed that way for about a month. When I finally finished the work and reconnected the battery, the PCM started throwing these codes. Oh, yeah, the original codes I had related to the CATS are gone now as I replaced the CATS and the 4 Oxygen sensors. The car runs fine, so I doubt there is a vacuum leak. I've tried clearing the codes, but they just come right back again and I'm sure that I haven't shorted any wires, so I'm thinking that maybe the PCM went bad after being dead for a month or so?
Ever heard of that happening?
Thanks for any advice.
Re: P0107 & C0240 codes won't clear
Do these show up as historic codes or active codes?
I only have the 2000 shop manual, not the 2002. But it shows P0107 as a possible short to ground on the MAP sensor circuit. On the earlier models, the MAP harness connector tends to dry out and crumble, producing shorts and opens. Might want to check that for loose or damaged pins. The code sets when the MAP sensor read below 0.10V, so that is an impossible operating condition. Has to be electrical.
C0240 shows as "traction control not allowed". Maybe 2002 is different. If you want the diagnostic charts I can send you a .pdf file. Do you have traction control? If so, is the "TRAC OFF" indicator lighted? If the problem resolves, the TRAC OFF indicator will be turned off, but the code will be stored.
A PCM doesn't go "bad" from not being powered. P0107 originates in the PCM. C0240 originates in the EBTCM (electronic braking/traction control module).
10-31-2016 11:09 AM
dluna333
15
03-13-2015 12:30 PM
z28projects4ever
9
07-16-2002 07:48 PM
